BFFB can be done by 2-man team. In this scenario staff man is just walking a lot.
Assuming 0.1mm standard error of taking a reading from the staff, BF method will give you every height difference with 0.1mm * sqrt(2) = 0.14mm error
But since BFFB averages two reading (BF) and (FB), its standard error is 0.14mm / sqrt(2) = 0.1m.
BFFB in a single run essentialy provides the same standard error as doing dual line BF levelling.
Sent: 02-13-2024 13:45
Subject: DiNi Level Simulator & measuring method
BFFB is used for highest accuracy level runs. You use two level staffs simultaneously, it's a 3 men job.
Main purpose is to evaluate the sinking of the change plates or your instrument while you do the measurement. If sinking occurs, then the difference between BF and FB will not match, and you do the reading again.
You still do the level run forth and back. Edwards suggestion is not the idea behind BFFB. From one BFFB observation (4 staff readings) you only get one single elevation difference.
You also want to use an even number of instrument setups between your control marks. The level staffs will have a minute but existing zero-point manufacturing deviation from each other.
With an even number of setups the reading on your control mark will be on the staff you took your first backsight to. And voila, there is no difference/error anymore.
That was a rather short version.
Sent: 02-12-2024 16:52
Hi Chao,
Depending on your requirements, these are different line levelling methods, e.g., you can complete one-way levelling using BFFB method (this gives you dual measurements per line). From one instrument setup, measurements will be taken at Backsight (1) - Foresight (2) - Backsight (1) - Foresight (2). before moving to the next setup. I guess people use this method to avoid having to level back to the start point and for more precise measurement?
As you mentioned - I prefer two-way / Loop levelling where you start and end on the same point - BF.
Found a bit of a discussion here -
https://rpls.com/forums/discussion/leveling-procedures-observing-sequence/
Sorry, not sure about the emulator - May have to ask your local sitech dealer.
Edward George
