Can't give you much feedback on that. It's rare that we create hardcopies with a printer. It's almost 100 % digital meanwhile.
Sent: 08-04-2024 16:55
Subject: Drafting Queries
Thanks Ronny - the Display Priority tip worked for me, so that's awesome.
Another thing I'm grappling with is the way hard copy prints from PDF render linework when I have a background aerial image. When you look closely at the linework, there's a razor-thin sliver of almost white page either side of linework and the image behind - I can only presume the printer is creating a 'gap' in the aerial for the linework i.e. rather than printing over the top, as it were. It wouldn't be too bigger deal if it was just in the odd isolated spot, but if I have include contours over the aerial, it becomes really noticable. I've placed a couple of images below; 1) the PDF on my monitor, 2) the resulting hard copy out of our office printer and 3) the best close-up I can get of the contour rendering issue mentioend above.
I suspect I'll be advised to use a better printer/plotter, but pretty sure I can run off plenty of other PDF docs containing plans and photo's on our office printer, that come out looking perfectly acceptable whereas the TBC PDFs are rough as guts?
Barney Brotherhood
Sent: 08-02-2024 18:28
Hello Barney,
that's a topic that Trimble doesn't bother to address since several years. I just pushed it to hour dealer a few weeks ago, again. And the usual answer was, yes those are known issues which have been pushed to Trimble several times.
1.
2. TBC is printing text always as line work, other programs can print text to PDF as selectable text (which makes the PDF smaller, searchable and the text can be scaled without loss of quality); it also depends on using the built-in PDF creator or i.e. "Microsoft print to PDF" which produces much smaller files at the cost of even worse quality
screen shots after using the Microsoft renderer
stroke font
or filled polygons true type font
the outline of a whiteout box seems to be a line, but the inside an image that's not 100% blending with a tilted whiteout outline
3. since the text is plotted as linework you'd imagine that they should be able to clip it easily at the sheet borders, at least during PDF creation, but it seems we're doomed to move text around manually to make sure it's either completely within or outside of the dynaview outline
