drill plan editing
  • 1.  drill plan editing
    Posted 02-04-2019 05:19
    can one edit a drill plan in certain areas not necessarily editing the whole plan but certain parts off the plan without changing already produced information.?
  • 2.  Re: drill plan editing
    Posted 02-04-2019 08:39
    Hi Brice,
    If you let me know what properties of the drill plan you want to edit independently, I can get you a better answer. Thanks.
    David
  • 3.  Re: drill plan editing
    Posted 02-04-2019 21:23
    You can select the drill holes themselves and change the selected drill hole properties. Each drill hole once created has a set of properties and the common ones like Inclination Angle, Orientation, Over Drill Depth, Drill Hole Length, Drill Hole size etc. can be modified individually or as a group.
  • 4.  RE: Re: drill plan editing
    Posted 10-28-2024 13:01
    Resurfacing this thread, seems like Drill Hole Size is applied to an entire drill plan. Is there any way a plan can have variable sized drill holes? When I create the drill holes, I can assign variable diameters, but once I export and re-load, all the drill hole diameters reset to the standard established diameter in the pre drill plan settings.
    David
    David Neuder
