If you isolate the layer with the items you want, and then copy those lines and relayer them to your "Roads" layer, your new lines will not be associated with the CAD file. In the Copy "From:" and "To:" Fields, enter "0,0" and "0,0" so the lines maintain their current location.
If you have AutoCAD, you can open the file and isolate the layer with the lines you are looking for and run the "WBLOCK" command. This will create a CAD file limited to the objects and layers you have selected. Then you wouldn't need to delete the CAD file in TBC to get rid of the 250 unwanted layers and objects.
Doug Veenker
