Im having the same issue. When I uncheck/check this box, the same thing happens when I try and export the data to 12d or CAD. Linework, points and other data simply disappear
Christopher Pepping
Sent: 01-15-2019 02:44
Subject: Re: Export Issue
Hi Carl,
I experienced somthing similar. Try to go to "Project Settings". Open the point "Feature Code Processing"
There try to check or uncheck the "Allow editing of processed feature codes...."
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/JiveInlineImages/142261.png)
My problem was, when i tried to eksport, the feature codes was processed ones again and all edits disappeard.
Good luck.
Carsten
