I see you chose "ground" in your export box. Have you tried using "grid" ?
I always choose "grid" because if I am scaling data to ground, I will do it in Local Site Settings instead of an export box. I'd rather be in control of data scaling rather than have a program choose scaling factors.
Robert Hoy
Sent: 03-14-2025 06:50
Subject: Export pointcloud to RCP crash problem
I am experiencing an error message when exporting to RCP in TBC Version 2024.10. it completes to 100% then the error message states "your selection could not be exported because the specified parameters are invalid" then tbc crashes and closes. i am exporting to my local drive and have more than enough space so any help with this issue would be great thank you.
Jacob Colvin
Sent: 06-02-2022 07:38
I think this is a memory problem. Crashed with 360 million points. Resampling and after that operated with 240 million points.
Attila Tóth
Sent: 06-01-2022 12:21
You might try and external hard drive connected to your local machine, but I was never able to do an export to a network drive... It always crashed like you described.
Thanks,
Peter Seaders, PE/PLS
Sent: 6/1/2022 1:49:00 PM
Subject: RE: Export pointcloud to RCP crash problem
I'm having the same problem. I select the cloud to Export, pick my save location and pick RCP as the save format and the moment I press save the program crashes with no information as to why. It hasn't corrupted my file thankfully. It's the only computer actively using the server (and there's not enough room on the desk top to try the round about method) so i don't think that that's the problem.
Unless someone knows another way to get point clouds out and into Revit which is the end goal.
Anna Teadtke
Sent: 11-17-2021 01:39
We have been having this same issue for months... Super frustrating. I tried Alan's solution, but that doesn't work for us. This has been the same on multiple versions (including most recent 5.60). no error logs created... just stops. We have 2020 and 2022 Recap installed, licensed, etc. I would really like to see a solution for this if anyone has one.
Peter Seaders
Sent: 09-16-2021 04:36
I may have found a solution, did you have only point clouds displayed and selected? i tried and had also got cad lines selected, I turn off everything but scan data, and it seems to have worked
Alan Cliff
