We are currently using TBC 5.90. I can't say for sure that this behavior didn't exist in TBC 5.81, but I don't recall having this as an issue.
We export a .csv file for each day of work that is associated with an imported Access .job file. If it matters, this is happening with Access 23.00. For example, after a day of field work, party chief takes .job from data collector and imports this file into TBC. The only data in that .job day file is the measurements from that day. All other prior existing data is linked into the empty .job day file at the start of the day. Once that day .job file is imported into TBC and QAQC is performed, as staked points are converted, then we use the Export command to generate a Point, Northing, Easting, Elevation, Description comma delimited .csv file. To capture the points associated with the .job day file we select the .job day file and use the select members options. We then export to the .csv.
We have been operating this way for years and haven't had this problem until recently. When we do this routine now, we get all the points as expected, but we also are getting some number of .csv rows that are missing their Point Numbers and Descriptions but are also duplicates of points already in the .csv list. The coordinate values are identical. I can't say I know why this would be happening. I have included a .csv file showing the issue and a screen grab showing the same as an illustrative graphic.
Please let me know if anyone has experienced this behavior before and what the cause and solution are.
Thank you,
Clayton Bradshaw.
Clayton Bradshaw
