I have a TSC5 survey controller with the latest trimble access software and I use Trimble Connect to import Navisworks BIM models as well as other CAD files. I then export to TRB file format and drag this over to the controller. All works very nicely.
The problem I am having is that the data flows in one direction and I cant get it back to CAD.
I see that the latest version of TBC can read in TRB files as well as other BIM models. I need to be able to export to DXF or DWG file formats.
So my question is as follows:
If I have a TRB file , can TBC export this to DXF or DWG.
I currently use TBC Ver 2.81 and it works just fine for engineering survey so there is no need to change to a different version.
the problem is that it wont do any BIM files.
If Im going to purchase the latest version of TBC , I need to know if its going to be able to export the data into a file format like DXF.
Andrew Newmarch
