I don't think I can help much with answering that.
I'd need someone in the Product team to chip in, as I can't see a usable way to decipher between what were under the hood tweaks and minor improvements versus something more major - e.g. an issue affecting lots of customers.
Sent: 08-19-2024 14:33
Subject: Exporting Shapefiles and GIS data
Hello Brendan,
so, as usual the release notes don't include all the changes that have been made, although it took them several weeks to put them on the website.
Are you aware of any other vital changes/improvements that they didn't bother to mention?
Sent: 08-18-2024 21:18
Hi Zach,
Like you say - ESRI changed a dependency and created a mismatch. I found the issue and it was addressed in the Patch release (but it didn't make it to the listed fixes in the Release Notes).
I updated to the latest TBC build and upgraded to ArcGIS Pro from v3.2 to v3.3. Shapefile & File Geodatabase workflows are working. Customers should be all good to move to ArcGIS Pro v3.3 with the updated version of TBC...
Brendon Edge
Geospatial Support Manager
Trimble New Zealand
Sent: 08-15-2024 16:50
I see that a patch was released. See here: https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/d96c6c61-308e-7a36-cff5-ff91c77835f6_file.pdf?AWSAccessKeyId=ASIAVRDO7IERFD6SZC4E&Expires=1723767850&x-amz-security-token=IQoJb3JpZ2luX2VjEOj%2F%2F%2F%2F%2F%2F%2F%2F%2F%2FwEaCXVzLWVhc3QtMSJHMEUCIQDl%2FaF4MuOJlPaVpXQHAq4%2FIwQp5lJBqwtTSWIqO7j%2BXwIgXDmHkXxRyOn7g0I4PzjPnqO%2BuTgM4lVPHadCb7zYUk0quAUI4P%2F%2F%2F%2F%2F%2F%2F%2F%2F%2FARAAGgwzODAzMzczNDA3MDYiDIat8u14Zjg9xIlUniqMBUdEylicsm7F3o%2FTprKIb%2Be0zWJG6ssf6lFaI%2BVJdzqsSuyFvzXssFGM1K8ZBkj6DEHT7gtHWMKGHvm%2FDjpMACSqIV11nkYSdomtoJssYRFeovlr3kdKtH%2BSrqaw9tE6%2BbNH0MTb7zXM3iQ833HfKfLR9hInXqpLlXMmVK2xLPGaDsu%2Bx%2BrcHFXdNuUYcwxZdST6nGwq4%2B7fEjLNlX0L3tMFfr%2FbtZsqVYvjWRM4Dqn0A21N01reQOHLRDlW9i8Ho9ZOm73Xxe1UEUR1gvb3bV8wctyau2yHEkDHdEEelvM%2BA%2B95mrxqmdDnV%2BIKdh%2BwSeteXe0I0EgxgkYJD0qjbCt748mxYpLQcpQVo0FMOMQSPZ6x58EBZlsW4xwHDMo5%2B688H0OYs9Qk%2F6P4OE5VpRb5vAGRdWizehGDx9JcscwU4cNdUQHlB0zbZi18AjYtRMSCYkPgMVwcMqg290gFzhI5NCKQD0CS8vj7x3Tb7QnT6EGEONuwyxGHWdyhq%2FFHyvHKfGyu1YJg%2B2yPKJxuvO8GCH1k9Ct5mpqZ35Vff5fyp4Z45ODXN2LGQhxqmMOnKTMTP4h%2FDxJh3HvLx2VJwDUU9O2vaohQTXo3r%2BlIuzrzry2wz8PBpM7gJdkMYwkNQTGKNY6PcIvlOHYdW%2FNNSzPDyHihKbWyw3IfbjLTj%2F7D7yYRskLfyOcXULmpukN1%2BjWzEFWUtFYqeFNyzuMWlIRdomdXwyZAXFECQbG2gH9ofrKPrzEmx9EfBN%2Bmpn%2FFyazy4ek%2BX%2Br%2Fs1CiBGCHmPir%2BVhGXkfu37AN%2FDrrz%2FAIOPJHw0kFkKouOCjx4nuwTuqapEcHgdCvUdz9agShUbDp0MiqrwGQ%2FyGfzKEw%2Fpr6tQY6sQE%2FF3n%2FnVV3gTfi%2BrcogmQu8StnMJdvkcE57YZs218quYvHAbxM4BEFPksBmEEb4%2Fisrcx0LG%2B1e5Ta%2F28AVS%2FJ643IxMeDJMne%2FKw1%2FLt62oGlFXpJQGzOQrROWa5wFPD0YpYCL9zAxzcFVJxAHTnFfZJRSmTD9qydkKujZExFwtTh45cXMMjqmuxlpeAhweBfi%2BY8uLuiYY%2Bh%2Fu2rT7Aprg7JRcqDs1gRr9uZQwYxNZg%3D&Signature=xVzq%2F%2Fw%2BIPryZvO0kTkMItVhc8M%3D. I see that there is no mention of the GIS import/export being fixed with users who have the latest version of ArcGIS Pro. Can someone at Trimble confirm if this fix was applied before I attempt to uninstall and install this latest 2024.01 full install?
@Shane Lyons
@Joe Blecha
Zach Edwards
Sent: 08-13-2024 15:16
My pleasure. I am hoping the fix for TBC will come this month still but we'll see.
Zach Edwards
Sent: 08-13-2024 15:03
Thanks Zach, this worked!
Roy Herrera
Sent: 08-13-2024 07:11
This is a known issue. Nearly every time ESRI updates ArcGIS pro, it seems like something breaks in TBC with respect to exporting shapefiles/GDBs, importing shapefiles/gbs, or using the GIS Module. The reason is because Trimble leverages ESRI's libraries to import/export. To resolve this, you can roll back ESRI's ArcGIS Pro 3.3 to 3.2 and it will resolve things. You could also uninstall ArcGIS pro 3.3 (likely not the best option). Lastly, you could keep ArcGIS Pro 3.3 and roll back TBC to the prior version. I have chosen to roll back my ArcGIS pro to 3.2 and everything works again. I am hoping the next patch of TBC will fix this. I am doing a webinar on the TBC GIS Module in September so hopefully sooner than later!
Zach Edwards
