Apparently the problem is with the .VCL export from TBC when using the 'clean up' property. If you disable that the designs work - but are often huge.
Charlie let me know they found the problem and it will be in a patch update soon.
Nelson Hays
Sent: 11-03-2022 05:20
Subject: Field Data Exports with 5.80 are busted....
I hope not with the DXF and TTM export...I usually do VCLs manually since the built in functions don't work with how we build models.
Adam Bower
