Yes, very simple solution to the problem. Going forward we'll remember for these specific situations to create 2 corridors.
Adam Bower
Sent: 04-27-2023 14:15
Subject: Flags on Surface I can't figure out
You may not want to hear this. You will want to make two corridors for this or make two different material layers for the left and right surface. Seems that the corridor surface is trying to cross over the Linestring in the combined surface. I did two surfaces from he Heaven Lane corridor and works with no flags.
Francisco Guerrero
Sent: 04-27-2023 05:19
Very confused where you're finding a flag at that location. I'm only getting 4 flags and they're not near that corridor. They're near Haven Lane and there are 4 of them. Not near any Concrete lines either.
Adam Bower
Sent: 04-26-2023 15:32
You have lines / surfaces occupying the same 2D location, but at different elevations.
You are assigning different elevation to the same 2D location. Hence the flags.
Try to review "Flags Pane". All issues are listed there.
Marian
