Can someone explain to me which option to use when? And what the differences are?
Backstory, field crew used the wrong epoch (2010) for a site. They set up a base with a known NEZ (previously processed to CanNet @ epoch 2002), and staked some points. When importing the field work to do some checks, I notice they used the wrong epoch, and switch it to the correct one, then I get the below dialog box.
If I select the top one I have to shift my base points NEZ back to the known coordinates. If I select the bottom, there is no shift needed
Jamison Ducolon
