tarrell.
couple things. tsc5 and 7 are two different things. tsc7 is a windows operating system and 5 is android based. so even though the software is the same(should be anyways) the background workings might be different and maybe some connection things might be different.
i see you are mentioning topo point. personally i use rapid point for general topo work and it is pretty fast on the 5. we have sp80 or 85 rtk heads and it is not as fast as survey pro on the tsc3, but it is reasonable and should not show excessive movement message.
the original post here was for rapid point. not sure if that problem is still going on on the 7 or not. but hopefully if you switch to rapid all will be good.
Sent: 8/4/2023 9:48:00 AM
Subject: RE: Has anybody notice that TSC7 when collecting Rapid Points is too slow?
Have you found a solution to this issue? I have a tsc5 which I think is the same as tsc7 just with smaller screen but I've found the storing of points to be slower than tsc3 as well and messed up my cross section survey as I was walking a long way. I tried updating Trimble version, creating new survey style, and new job without template and it still does it. Topo point set to 0 instead of 2seconds seems to almost be better but it prompts and "excessive movement" every time I measure which I have to bypass it's super annoying. Any response is helpful I can't believe a newer machine performs slower and less reliable than the tsc3. Thanks for any help
Tarrell Block
