if you are using a boundary to trim the surface. Try breaking the surface and make two surface. that way you wont have to make a boundary to void out the middle. Or another though, try adding a Material using the MSI at the middle. The Material placed must be a a empty material meaning when you drop a MSI and it gives you choice of which material to drop pick none.
Francisco Guerrero
Sent: 06-16-2022 05:44
Subject: Holes in surface wont show in cross-sections
Just tried it and did set the length to 4m and it was still the same.
Fredrik Bergstrom
Sent: 06-16-2022 05:33
is there a chance that the surface edge length needs to be changed. possibly the cross section is reading the surface even if there is a boundary.
Francisco Guerrero
Sent: 06-15-2022 11:32
Its not the slicer viewer thats the problem, it works in that one, its the XS plans.
Fredrik Bergstrom
Sent: 06-15-2022 11:27
did you ever find the problem? I did a test surface with a hole. I am able to generate a hole in the slicer view.
Francisco Guerrero
Sent: 06-14-2022 06:41
Fredrik Bergstrom
Sent: 06-14-2022 06:12
can you show the actual surface in plan view.
Francisco Guerrero
