For TBC to TBC always use VCL format files - in Export - Construction - it is at the bottom of the list - That lets you select any type of TBC data and export it with full "richness" i.e. for a HAL it will export the HAL, VAL, Super and Station Equations etc. VCL is actually the same as a VCE File but with Survey and Coordinate System Information stripped out
Outputting data to 3rd party software then depending on the software / region you are working in will dictate the right method - LandXML is pretty common worldwide, 12D in Australia, GENIO in UK, REB in Germany etc. All support alignments (but not all functions of the alignment (like Superelevation)
Hope this helps
