Good one. Didn't think of that page anymore.
Usually I only go there to look up antenna dimensions.
Never had to extract position information from a T0x. Either it's stored in Access or the T02 is going into base line processing.
Out of curiosity, is the elevation in the output already reduced to pole tip, or is it APC (antenna phase center) or antenna mount?
Sent: 02-20-2024 08:53
Subject: How can I obtain the coordinate in every epoch i collected from RTK survey?
You can extract positional information from a T02 file using the utilities on this website https://trimbletools.com/
It will create KML and position statics as well.
Kenneth Watterson
