How to Calculate Demolition and New Pavement Quantities Together in TBC (Similar Existing & Design Contours)
  • 1.  How to Calculate Demolition and New Pavement Quantities Together in TBC (Similar Existing & Design Contours)
    Posted 02-13-2026 11:03
    Hello Everyone,
    I mostly work on site renovation and improvement projects, and I frequently deal with demolition quantities along with new construction quantities in the same area.
    I would like some guidance on how to properly calculate demolition and new pavement quantities together in Trimble Business Center.
    Here is my scenario:
    • Existing asphalt pavement removal: 15 inches thick for 220 SY
    • New asphalt pavement placement: 18 inches thick for 180 SY
    • Remaining area: 6 inches of topsoil (landscape)
    • Existing and proposed contour lines are almost the same throughout the site.
    Since the existing and design surfaces are nearly matching, I am unsure how to correctly model and calculate:
    1. The demolition quantity (asphalt removal)
    2. The new pavement build-up
    3. The landscape/topsoil placement
    4. Any necessary elevation adjustments
    How should I properly set up the surfaces and volume calculations so demolition and new pavement can be handled accurately in the same area?
    How can I perform demolition takeoff directly from MSI Manager?
    • Can demolition be modeled as a negative depth item?
    • Or should it be handled through a separate condition layer?
    • What is the best practice to avoid conflicts between removal and new construction quantities?
    I would really appreciate if someone could explain the correct method or workflow in TBC for this type of renovation project.
    Thank you in advance!
    Keith Delehanty
