Hi Marianne
Thank you for your response.
I have an additional question. I would like to set the generated points to scan inspection.
I want to set them in scan inspection but they are not added.
How can I add points at grid intervals in a scan inspection on a projected plane?
다솔 박
Sent: 06-26-2024 20:24
Subject: How to create grid-spaced points on a surface
1) Create another Projected Surface using the same plane. USe the same Surface Members
2) Create cut-fill map betweem those two suraces.
3) Make CFM Grid only, no shading.
4) Explode CFM.
Marian
