Hey Zach,
I tried the different things you mentioned but It still disappears. Even if its on a layer that's visible.
Robert Fox
Sent: 02-10-2026 12:57
Subject: How to use a linestring as a spot point
Robert,
Might it be that you simply have the layer turned off or, if the linestring has a zero elevation(s), you may have the view filter manager set to NOT display zero elevations under the display options tab?
Zach Edwards
Sent: 02-10-2026 08:02
I find it easier to use the linestring method due to being able to name each item am counting on the fly.
Robert Fox
Sent: 02-09-2026 13:17
Why not just use a point as a count?
Erik Petersen
