Hello Mark,
The OS zip download contains data in both RINEX version 2 and version 3 format (.rnx extension). You can use either type with more recent versions of TBC, so you have to pick which file type you wish to use. if you have an older copy of TBC it may not support the newer .rnx file type.
Although you can bring zip files into TBC, I prefer unzipping first and then dragging in only the files required.
The data processing time must be down to the process you are applying and the PC specification. More info would be need on that in order to provide any advice.
From the OS web site:
RINEX file naming conventions
RINEX 2 format files
nnnnDDDS.YYt[.cmp]
where:
nnnn = 4 character station ID
DDD = 3 digit day of year (inc. leading zeros) of first epoch of data in the file
S = Hourly session ID letter corresponding to first epoch of data in the file.
"a" = 00:00:00 - 00:59:59 (GPS time); "b" = 01:00:00 - 01:59:59; …. ;
"x" = 23:00:00 - 23:59:59
YY = 2 digit year (inc. leading zero) of first epoch of data in the file
t = File contents indicator. "o" = observations; "d" = Hatanaka compacted observations;
"n" = GPS orbits; "g" = GLONASS orbits
cmp = [Optional] Compression method. E.g. "zip", "gz"
RINEX 3 format files
nnnnMRCCC_S_YYYYDDDHHMM_PPU_FFU_CT.fmt[.cmp]
where:
M = Monument number. Currently only zero (0) is used
R = Receiver number. Currently only zero (0) is used
CCC = ISO country code (GBR)
S = Data source. "R" = receiver; "S" = stream; "U" = unknown
YYYY = 4 digit year of first epoch of data in the file
HH = 2 digit hour (inc. leading zero) of first epoch of data in the file (GPS Time)
MM = 2 digit minute (inc. leading zero) of first epoch of data in the file (GPS Time)
PP = 2 digit file period (inc. leading zero)
U = Units of period PP. "M" = min; "H" = hour, "D" = day; "Y" = years;
"U" = unspecified
FF = 2 digit frequency of the observations (inc. leading zero)
U = Units of frequency FF. "C" = 100Hz; "Z" = Hz; "S" = sec; "M" = min;
"H" = hour; "D" = day; "U" = unspecified
NB - _FFU is omitted for files containing navigation data
C = Constellation indicator. "M" = mixed; "G" = GPS; "E" = Galileo;
"R" = GLONASS; "C" = Beidou; "J" = QZSS; "I" = IRNSS; "S" = SBAS
T = Data type indicator. "O" = observations; "N" = navigation;
"M" = meteo (no associated constellation so MM)
fmt = File format indicator. "rnx" = RINEX; "crx" = Hatanaka compacted RINEX
Example
One hour of data from station LEED, 29th July 2021 (DoY 210), starting 09:00 (GPS time), 30 second data rate,
mixed constellation, zip compressed.]
RINEX 2 filename = LEED210j.21o.zip
RINEX 3 filename = LEED00GBR_S_20212100900_01H_30S_MO.rnx.zip
Richard Selby
