I have conducted some scans around the university campus using the MX50 Lidar scanner.
After generating the scan from the trajectory, the point clouds exhibit a significant elevation difference between the point cloud generated from the left scanner head and the one from the right scanner head (as shown in Figure 1). Additionally, I have other point clouds where the objects display various degrees of offset (as depicted in Figure 2).
I am uncertain about which tool within the TBC software I can utilize to refine these issues. I have completed the ground survey, but I am unsure if the survey data would be beneficial. If the survey data is helpful, could you guide me on how to use it to fine-tune the point cloud?
Thanks in advance!
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/MessageImages/f10b4de2a32c44668489302fff4c9df2.png)
Figure 1
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/MessageImages/ca98c2f81a1e41a09eaaf470299d1e1d.png)
Figure 2
Jurij Karlovsek
