Good morningI would like to ask you to send me a solution to the problem regarding checking the verticality of structural columns after installation and presenting the results based on a point cloud. I will add that I do not mean the functions available in TBC - inspection based on scan to scan or scan to designed plane. I would like to do it in a similar way that is available in Trimble Access when inspecting a vertical plane scan.
Thank you for your help
If you have a 3D cad file of the column, you could do a Scan Inspection and use the scan to 3D object inspection.
