Is anyone else getting this OMP warning?
  • 1.  Is anyone else getting this OMP warning?
    Posted 01-22-2019 11:06
  • 2.  Re: Is anyone else getting this OMP warning?
    Posted 01-22-2019 14:00
    When is this happening Ben - I have never seen it - what function are you running to generate this message?
  • 3.  Re: Is anyone else getting this OMP warning?
    Posted 01-22-2019 14:55
      |   view attached
    Alan,
    It happens at startup.  As the TBC loads up this pops up and stays up as a separate window and doesn’t go away until I shut down.  After running TBC for a while there will be this as well.  If I try to close the window it kills the program as well.
    Ben
  • 4.  Re: Is anyone else getting this OMP warning?
    Posted 01-23-2019 10:34
    Alan, I replied to the email message that was generated.  I was just wondering if you got it or if I need to reply in here instead.
    Thanks,
    Ben
  • 5.  RE: Re: Is anyone else getting this OMP warning?
    Posted 11-23-2022 17:28
    Hola, tengo el mismo problema, tengo una laptop AMD Ryzen, me sale el error OMP 72 sobre KMP_affinity deshabilitado
    Julio Froylan Solano Choquehuanca
  • 6.  RE: Re: Is anyone else getting this OMP warning?
    Posted 11-23-2022 17:37
    See Tim McClannahan's response below.
    James McWha
  • 7.  Re: Is anyone else getting this OMP warning?
    Posted 01-25-2019 07:25
    The problem appears to be related to how the software sets up the Multithreading on your computer. There has been some reported issues with AMD Processors that apparently do not support the threading correctly for Windows OS and this may be what you are seeing since you are using an AMD Processor Ben.
    I will push again today to get you a response on how to move forwards here.
  • 8.  Re: Is anyone else getting this OMP warning?
    Posted 01-25-2019 15:31
    In TBC 5.00 a component was added which makes use of Intel's internal threading API.  This API is not supported on certain AMD Ryzen processors.  The effect is that when you start the program, a text box is created that displays an error message similar to the following: “KMP_AFFINITY: affinity not supported, using “disabled””.  If you close the text box, TBC will crash.  We are working to get a computer to duplicate the error and so far have not been able to find the change that causes the problem.
    I believe that you may be able to set an environment variable that will disable this, but without a computer I cannot verify it.  Try setting  KMP_AFFINITY=disabled and let us know if this corrects the problem.
    Go to control panel>system>advanced systems settings>environment variables>
    Create a new system variable
    Name = KMP_AFFINITY
    Variable value = disabled
    Start TBC and see if the problem still persists.
    Tim
  • 9.  Re: Is anyone else getting this OMP warning?
    Posted 01-26-2019 01:30
    Hi Tim,
    I'm also getting this error on my new PC. I have an AMD 2950 with 16x cores. As already described, as long as you don't close the command window, TBC seems to work.
    I'm now travelling and coming back to the office next Friday, so if you want to access to my machine via TeamViewer to test whatever needed, please let me know.
    I'll be able to try it with the environment variable also next friday as I have the dongle with me, and I think the error doesn't come if you launch TBC in viewer mode without the dongle.
    Thanks.
    Fernando
  • 10.  Re: Is anyone else getting this OMP warning?
    Posted 01-26-2019 01:33
    BTW, if you want to try sooner, one colleague can start the PC and give you access via TeamViewer so you can add a 30 days trial code so the error should also pop up if it's not reading the dongle but a current valid license instead.
    Please let me know if I can help
  • 11.  Re: Is anyone else getting this OMP warning?
    Posted 02-03-2019 05:58
    Hi Tim,
    I was finally able to try this and after creating the environment variable and setting it to "disabled", indeed I don´t get the error message any longer, so it seems to fix it.
    Thanks for the workaround !
    Regards,
    Fernando
  • 12.  RE: Re: Is anyone else getting this OMP warning?
    Posted 11-23-2022 18:09
    hola buenas tardes estimado tengo el mismo problema te adjunto las imagenes que me salen te agradeceria me puedes ayudar
    Julio Solano
    Operador/Piloto RPAS
    Lima/Perú
    +51965490433
  • 13.  RE: Re: Is anyone else getting this OMP warning?
    Posted 11-23-2022 20:25
    I would suggest running the Trimble Office Clean Up utility and then reinstall TBC.
    The clean up utility can be found here:
    https://geospatial.trimble.com/trimble-business-center-utilities-license-and-installation-support
    If that does not fix the problem then please contact your local Trimble Dealer.
    James McWha
  • 14.  RE: Re: Is anyone else getting this OMP warning?
    Posted 01-10-2023 17:26
    This is great, thank you. Works perfect.
    Tylor Foster
  • 15.  RE: Re: Is anyone else getting this OMP warning?
    Posted 11-16-2024 08:54
    Perfect Fix Thank you!
    Joshua Waite
  • 16.  Re: Is anyone else getting this OMP warning?
    Posted 02-04-2019 23:36
    Awesome Fernando -Thanks for the update - Good to know that this works on at least your PC
    Ben - Hopefully you have seen this and have tried it also - can you let us know if it also worked for you too
    Thanks
  • 17.  RE: Re: Is anyone else getting this OMP warning?
    Posted 05-21-2024 08:41
    I can confirm this does not work on every PC.  When I change the system variable I get "Exception has been thrown by the target of an invocation".
    I have an AMD Ryzen 9 5900X 12-Core and a AMD Radeon RX 6950 XT
    Kent O'Donohue
  • 18.  RE: Re: Is anyone else getting this OMP warning?
    I am getting this error and the system variable suggestion above did not fix it and running the utility tool did not fix it.  I installed Trimble 24.0.0 and I have an AMD processor and GPU.
    Kent O'Donohue
