LAS 1.4 Files
  • 1.  LAS 1.4 Files
    Posted 03-30-2023 04:54
    TBC does not seem to be georeferencing LAS 1.4 files properly.  The older LAS 1.2 georeferences with the key/value and the newer 1.4 uses WKT.  Is anyone else having the same problem?  If so, is there a fix
    James
    James Shores
  • 2.  RE: LAS 1.4 Files
    Posted 03-31-2023 07:28
    Yes I believe I have noticed some issues as well.  I was receiving third party .las files and they were in the 1.4 version and TBC acted like it didn't know how to read the data.  I think I ended up having to bring them in as unreferenced point cloud and I had to check back against the panel point data to make sure they were where they needed to be.  It seems like there might be something in the header of the new format that is confusing TBC.  But the data seems to be good as far as I can tell.  The kicker is that civil-3d reads it and pulls it in no problem.......
    Ben Ryschon
    Paul Reed Construction
    2970 N. 10th
    Gering, NE  69341
    Ph. 308-635-2213
    Cell 308-631-3712
