In TBC, I ran the Feature Code Processing on a topo. It returned several errors, which I then fixed. When I mentioned this to the surveyor, he said the linework appeared just fine on his controller with no errors.
This is a bit disconcerting, because now I wonder how I can be confident that the linework processed in TBC is exactly what the surveyor knows it looks like based on what he sees on his controller in the field.
I used to assume that the same parsing algorithms were used on the feature code regardless of whether it was TBC or Access. But based on this it appears that Access may have a more robust or forgiving parsing ability than TBC.
I welcome any insight or comments on this. Thanks!
Bob Epstein
