Sent: 12-20-2023 12:48
Subject: Machine control files
im trying to figure out what files I need from the surveyor to be able to convert it to the machine? What are the 3 files needed? See Attached PDF
Does the site calibration need to be done in order for the files to work in the machine? Yes, you need a .cal file for 995s
See attached and what file structure it needs to be in
Erik Petersen
Sent: 12-20-2023 12:22
thank you for your help,
John
John Harleman jr
Sent: 12-16-2023 09:15
Hi John
if you don't have a site calibration then it will say grid when it use your choice of coordinate system in your project
you can use DXF, DWG, TTM, Land XML as linework and surface designs into TBC
Export from TBC into your D5 should be " Machine Job Site Design Exporter under the construction tab
There you also can choose your background map as well
When you're about to export all 3 files that's needed for the GCS 900 system you'll need to do one last choice under settings in the exporter tab.
which controller software version you have in the dozer and what MS 99? Version you're running.
MS 990 and 992 uses .cfg file for configuration and MS 995 and 996 uses .cal for configuration.
So you have to enable MS 990 compatibility if you're running an older receiver
I hope you got some answer to your question
BR
Daniel 🇸🇪
Daniel Hjelm
