Thanks for the tips. I did find that if I I export a TDX after registration the scans lose their registration association when I import them again. I also learned more about the View Filter Manager where I can turn off scans to speed up processing. I saw on a previous post where you mentioned changing the physical RAM to avoid crashing. Mine was sitting at 8 GB and I have 128 GB and changed it to 64 GB and it seems to have helped.
In total I have 228 scans across 16 days. Should I register them all together in one big registration, or should I just keep each individual scan day registered and georeferenced on their own?
Paul Keays
Sent: 01-24-2026 12:26
Subject: Managing a large scan project
Paul,
Your workflow seams reasonable. Whether using Trimble Perspective or Fieldlink with the tablet and X9, you are doing a station by station in-field registration. It's up to you whether you observe precision points to targets (DR shot). If you have a proper target (i.e., 6" checkerboard target), remember that you can automatically extract those in the latest two versions of TBC (2025.20 or 2025.20.1). Extracting the target from the scan data is more efficient (in my opinion) as opposed to taking the DR shot (precision point) to said target in the field. The extraction of the target coordinates in my testing has been more accurate than I can sight the target with DR in the field. Each day after the last station, you can refine and export to TDX. Then bring said TDX into TBC. Continue to add those exported TDX files each day. If you have an issue georeferencing to extracted targets, remember that you can do a cloud to cloud (pairwise) registration from day one (all scans) to day two (all scans). Alternatively, you could create groups of stations in the field and then continue using the same Perspective (or FieldLink) job for all days on that same job. That is really up to you. See here for more on the target-based extraction/registration tool in TBC versions 2025.20.1 or 2025.20: https://youtu.be/na1hqYxRiwY?si=qtPqndX6Xx60DacH.
Zach Edwards
