or does someone have a traverse file they can share ???
Francisco Guerrero
Sent: 02-17-2026 13:12
Subject: Manually entered Traverse. one time deal
so, is someone willing to calc this for me !!!!!!!!!manually
Francisco Guerrero
Sent: 02-17-2026 10:48
Adjusting a traverse in TBC, and TBC in general, is very much for working with observation data directly from one of Trimble's data collector raw files, not for entering survey observations manually.
Robert Hoy
Sent: 02-17-2026 06:52
I did not have the license or software in the DC to do a traverse. So I am trying to get the angles in TBC from point to point.. unsure what is the correct method to get the angles or azimuth. I have seen something about adding azimuth and then subtracting angles. I just have tried that yet and what to look for.
Francisco Guerrero
Sent: 02-17-2026 06:36
I am not sure what you mean by "correct angle"? Can you elaborate on that a bit? Typically, one imports angle sets from the field and then uses the Traverse adjustment command to adjust the traverse. Control points can be assigned in the adjustment routine.
Sean Lahann, PLS
Phoenix, Arizona
