Mapping FXL LineWeight Indices to Millimeters (mm)
  • 1.  Mapping FXL LineWeight Indices to Millimeters (mm)
    Posted 04-22-2026 10:12
    Hi everyone,
    I am currently working with Trimble FXL files (Schema Version 9) and I'm trying to understand the exact conversion logic between the LineWeight attribute found in the XML and the actual line thickness displayed in Trimble Business Center (TBC).
    In the linestyle.xsd and the FXL files, the LineWeight is defined as a positiveInteger: <Line Color="Empty" LineWeight="1"> <sources-carousel-inline ng-version="0.0.0-PLACEHOLDER" _nghost-ng-c547101585=""></sources-carousel-inline>
    However, in the TBC interface, these weights are represented in millimeters (e.g., 0.13mm, 0.25mm, 0.35mm). Since the Units are set to Reference="Paper" and Length="Metric", I assume there is a fixed mapping table used by Trimble software to interpret these integers.<sources-carousel-inline ng-version="0.0.0-PLACEHOLDER" _nghost-ng-c547101585=""></sources-carousel-inline>
    My questions for the community:
    1. Is there an official mapping table that correlates the indices (0, 1, 2, 3...) to specific millimeter values?
    2. Where is this translation stored? Is it hardcoded in TBC/Trimble Access, or is there a support file (like a .dot or .config) that defines these values?
    3. Consistency: Does LineWeight="1" always result in the same mm thickness across different Trimble platforms, or does it vary based on display resolution/DPI settings?
    For context, I've analyzed the fxl_9_4.xsd and linestyle.xsd, but they only define the data types, not the unit conversion logic
    Any insights or links to official documentation would be greatly appreciated!
    Best regards,
    Julian Weber
  • 2.  RE: Mapping FXL LineWeight Indices to Millimeters (mm)
    Posted 04-23-2026 08:41
    Julian,
    The LineWeight element value is the lineweight in mm multiplied by 100.  This is the same convention used in DXF files.  E.g. lineweight in TBC of 0.13mm is a LineWeight value of 13 in FXL.  TBC lineweight of 1.58mm is FXL LineWeight of 158.
    The valid enumerations also follows the DXF convention, the possible values are 0, 5, 9, 13, 15, 18, 20, 25, 30, 35, 40, 50, 53, 60, 70, 80, 90, 100, 106, 120, 140, 158, 200, 211.
    Andrew Klingenberg
