You can also go into your C:\Trimble Synchronizer Data\MP TSC7\Trimble SCS900 Data folder, and delete, rename or move the Allsites.xml out of that folder, then when you restart Siteworks it will ask you where you want to map your data folder to, in which case just make sure it says C:\Trimble Synchronizer Data\PC\Trimble SCS900
If you really want to get fancy there's a registry setting at: Computer\HKEY_CURRENT_USER\SOFTWARE\Trimble\SCS900\Folders that if you change the "MP TSC7" to "PC" that should re-map the emulator to the device you want.
Steve DiBenedetto
Sent: 03-17-2023 15:32
Subject: Mapping Siteworks emulator
In that case you'll need to move the folder someplace else for a few minutes.
Restart the simulator, that will now ask for a new folder, so point it to the new one.
And now move the other folder back.
Sent: 03-17-2023 09:23
I can't delete or rename that folder because that is an active field tablet
Tom Silicato
Corrado Construction
New Castle, Delaware
tsilicato@corrado.com
www.corradoconstruction.com
Sent: 03-16-2023 14:06
Just delete or rename the old folder and restart Siteworks, it should ask for a new layer location afterwards.
