Thanks Tex.
I was able to download the files from the Trimble Connect project. I will try to get the data to the point cloud team and add your screenshots so they see the current state.
We are currently in the final release state of TBC v.5.90 and work mainly on critical bugs, so I assume even our issue here is a bug, but as the option with changing the shader is a possible workaround, we will probably move it to the next release for fixing, which means for the next 2-3 weeks I do not see it getting fixed.
Thomas Widmer
Sent: 04-20-2023 10:58
Subject: Microdrone / MdInfinity point clouds
Thomas,
The default was set to "Normal Shading". I sent you an invite to a Connect project with data and screenshots. You will see I also have the original LAS form MdInfinity and TBC will not show the intensity unless it is ran through Recap and exported to an E57 first.
Tex Barnett
Sent: 04-19-2023 02:34
Hi Tex and Sage,
was the shading by default set to "Normal Shading Mode"?
Tex if you find the time please let me still access your data so I can reproduce it on my side with the current build and I can investigate it further.
Thank you Sage for the help!
Cheers,
Thomas
Thomas Widmer
Sent: 04-18-2023 11:19
Yep, that was the answer. I wish I would have known that before I went next door and kicked my neighbor's puppy.
Tex Barnett
Sent: 04-18-2023 08:45
Our drone data will show as all black if we have the shading mode set to "NORMAL SHADING MODE". It shows colors when it is set to ambient or none.
Sage
Sage Root
