That's surprising.
Sent: 01-30-2025 11:45
Subject: Most efficient way to create multiple points with station/offset
Hey Ronny, I just tested the RPS Station / Offset Points command again to confirm nothing has been updated. The Horizontal component is dependent on the source line/alignment, but the vertical delta is not.
Nelson Hays
Sent: 01-23-2025 14:23
My tool doesn't create dependent points, the points won't move if you move the line. I never needed that myself, and I always prefer simple CAD points that don't have a name/number and won't show in the project explorer. I always leave the number-column-field empty when I run my macro.
But they'll receive the line's position and elevation, or with an added horizontal/vertical offset.
The big advantage over the "TBC Excel" approach is that you don't need an Alignment, it works with any Line.
I had a brief look in the SDK and it seems fairly simple to implement the creation of dependent points with Station/Offset and deltaElevation in the near future.
The Trimble.Vce.Alignment.LocationComputer.DependentPoint is what the TBC-"Create Dependent Point" creates and that one is a simple CAD point as well. And specifically has the option for deltaElevation from the source line.
Are you positive that the RPS macro doesn't create vertical dependent points if you set "elevation mode" to "delta"?
Haven't updated RPS in ages, and their webpage recently always wants your contact details when you just want to see the tools list. The tools list and what is free and what is to pay for isn't as clear as it used to be on older versions of their webpage. Is that one for free or is it one of the paid ones?
Sent: 01-23-2025 13:17
Ronny, is your tool dependent on the source line?
RPS took over the Trimble Station / Offset Points sample macro command, and it does allow for delta elevations as well as dependency to the source object - however only in the horizontal. I want vertical dependence...
Nelson Hays
Sent: 01-22-2025 15:41
There are at least two ways.
One is built in, open the TBC help with F1 and search for "TBC Excel" (example here IMPORTING POINTS FORM EXCEL | Trimble Business Center)
The problem with that one is that the elevation must be absolute, it can't be relative to a linestring. You'll have to elevate the points i.e. with a DTM.
My public macro collection (https://github.com/RonnySchneider/SCR_Macros_Public) does include a macro called "SCR_ImportStaOffEl" that allows the elevation to be absolute or relative to a line and doesn't necessarily need a point number column.
If you tick the "relative" box but still enter a column for elevations than those values act as vertical offset from the reference line, i.e. different bolt projections. Had handrails/screens with different types of bolts/projections along the same reference line. In combination with my "SCR_AddHogToLine" macro you can quickly create bolt patterns with correct elevations for different construction stages, deck sag values.
AnzToolbox has a similar macro to mine "Points from Chainage Offset", but at least the old version that I have only supports absolute elevations when using a CSV file, so not much better than the TBC Excel approach. At least you can define the order of the columns, like in my macro.
RPS might have something similar as well.
