In addition to Charlie's recommendation, which is the cleanest way to do it, once you enter this 'cutoff template', you can resume your corridor with a reference template linked to the last one before the cutoff. I usually try to build all my corridors in one template, so this is pretty straight-forward. Oh I see someone jumped in with this while I was sitting on it!!
Another way to build gaps, if you are building your corridor using nested tables, is to use a '?' in a nested table at that 'cut-off station and resume the corridor at a station later. This is more practical when you are only having certain nodes come in and out, however, not gapping the whole corridor.
Dave Olander
