My tech shared his screen with me and this project had all sorts of data in it from old projects and this new project (imported grid points, RTK, optical, static GPS...). I told him to start stripping out any data he didn't need from the old projects. He ran the adjustment and it worked.
Tex Barnett
CEI Engineering Inc.
Bentonville AR
Sent: 02-17-2022 22:27
Subject: Network adjustment could not be successfully completed. Numerical Problems
This is a core error in the network adjustment module which could be related to the calculation of the correction in the adjustment process, or you might have stations which their coordinates cannot be computed and as a result, the matrix of normal equation coefficients becomes singular and TBC suppresses any attempt to solve the normal equations.
What type of observation do you have in the adjustment? Did the error occur in the constrained or the free adjustment? If you are doing a constrained adjustment check your fixed coordinate and make sure they agree with the observed data and the coordinate system definition.
Ramin Rad
