typically you should also turn curvature correction on in your data collector. it should be in the settings on your station setup, and will pop up every time if you enable it to with the page that prompts for temperature and ppm.
will likely not matter too much on short measurements, but on longer shots and maybe depending on what coordinate system you are in you will likely want this on. and then you will not get the error in tbc.
ian bissonnette
Sent: 07-21-2023 00:01
Subject: Network adjustment curvature correction eror
You need to change the properties for the station set up in the project explorer.
Ben Henderson
