Thanks a lot Shaune.
I will investigate thoroughly and update you.
In the said level runs, the AF, AK or AE change points are not monumented points. There SHOULD BE NO DUPLICATES. MA*. ME* are monumented. A repetition should produce near same elevations. I think that TBC usually splits the runs here while doing a "Network Adjustment" or so I believe, I may be wrong.
Honestly, I had not looked seriously at the AF, AE, AK series of points. I will now investigate thoroughly.
Thanks for the help.
Regards.
The information transmitted through this mail is confidential and may be legally privileged. Access to this mail other than the intended recipient is unauthorized. If you are not the intended recipient, please notify us or erase contents. Any re-transmission, dissemination, action or omission based on the content of this mail by persons other than the intended recipient may be unlawful and strictly prohibited. We monitor email communications through our network. Any violation for the above norms may lead to prosecution.
Sent: 4/5/2023 8:32:00 PM
Subject: RE: Network Adjustment of levelling work- Trimble DiNi in TBC 5.81
Hi Saif,
I have had a quick look at your files and notice you have what i am assuming is a lot of change points (AFxx and MAxx series of points) that have multiple level level runs to them.
From my expereince in the past, I have been caught out when i have gone through common change points however the guy holding the staff has not held the staff on the same point as previous. This means that the reduced level for what i thought was the same point will be wrong, however TBC takes the point names as gospel and will try to match them up and throw an error to say the readings are out of tolerance because you are not comparing the same reduced level.
A prime example of this is using top of bolts to change on, however if the same bolt is not used in each run (because the staff holder forgot which one they used previous) but you type in the same name into the DiNi, there will be slight errors in the level run as there may be 10mm height difference between the bolts, TBC will however take it as gospel that these two change points are the same point and match them in the level run, throwing a small error.
Another issue can arrise when the DiNi auto-incriments the point number and can accidentally overlap a previous used point number, the reading you have taken for a completely different change point. TBC will then match these runs and throw a larger error.
Looking at your data, point AF-29 has thrown up 3 errors of 0.353, 0.353 and 1.265m and there are six legs that link through this change point. These legs might not actually be tying into this point correctly as they have either:
- been named AF-29 incorrectly and the reading is actually for another change point somewhere else on site (most likely to throw this large of an error)
- change point is AF-29 but the reading hasnt been taken on the correct point (like the bolt example above).
Going forward, there is no magical solution if this is the case to resolve, i would focus in on point AF-29 and rename some of the change points in the runs linked to this point and recompute. If you are familiar with where these points are on site, one may stand out to you as being an incorrectly named leg. (For example: E41 and E692 are both MA-110 to AF-29 however E695 is MA-111 to AF-29 so maybe MA-111 is labelled incorrectly and should be MA-110 as well). It may as simple as one leg throwing the whole adjustment out!
Shaune Dorron
