No elevation on linestring
  • 1.  No elevation on linestring
    Posted 08-21-2022 09:52
    I am having a problem with elevation while creating a linestring. The snapping to an existing arc does not apply the elevation of the arc to the linestring.
    I can snap to any other part of the arc, besides the endpoints and the elevation will transfer.
    I appreciate any help on this situation.
    Daniel Rupp
  • 2.  RE: No elevation on linestring
    Posted 08-21-2022 14:19
    Which version exactly are you using?
    5.60
    5.60.2
    5.70
    5.70.1
  • 3.  RE: No elevation on linestring
    Posted 08-22-2022 05:14
    Ronny
    I was using V5.70, i upgraded to V5.70.1 and the problem still exist's.
    The arc i try to endpoint snap is from an imported cad file. i tried the remove UCS with no luck.
    Dan
    Daniel Rupp
  • 4.  RE: No elevation on linestring
    Posted 08-22-2022 10:57
    I'm surprised you're still seeing the issue on v5.70.1. Can you send me the data and if possible a quick video of what your exact steps are to reproduce the issue?
    Charlie Sorg
    Product Owner
    Trimble Business Center, CIS
  • 5.  RE: No elevation on linestring
    Posted 08-22-2022 11:23
    Update: I cannot reproduce the issue in v5.70.1 with linestrings I created in TBC. What type of object is it that your end point snap isn't adopting the elevation from?
    Charlie Sorg
    Product Owner
  • 6.  RE: No elevation on linestring
    Posted 08-24-2022 05:40
    Charlie
    Unfortunately i deleted the original arcs and just created in TBC and saved over original file.
    The problem is not from linestring created in TBC, it was a cad polyline imported from civil 3D.
    I will update the thread if i encounter the problem again.
    Thank You
    Daniel Rupp
  • 7.  RE: No elevation on linestring
    Posted 08-24-2022 08:16
    Thanks for the update, I'm happy to dig into it if you can provide the data to work with that causes the issue.
    Charlie Sorg
    Product Owner
