I've restarted tbc, the computer, tried using the command promp, i cant export the CAD data in this project and the null reference exception seems to be happening more frequently as of late using multiplte tmls. never saw this before 5.50
Exception Count: 1
Exception Source: Trimble.Vce.UI.BaseCommands
Exception Type: System.NullReferenceException
Exception Message: Object reference not set to an instance of an object.
Exception Target Site: bmv
---- Stack Trace ----
Trimble.Vce.UI.BaseCommands.ExportCmdUI.bmv(Object a, SelectedTabChangedEventArgs b)
Trimble.Vce.UI.BaseCommands.DLL : N 01028
Infragistics.Win.UltraWinTabControl.UltraTabControlBase.OnSelectedTabChanged(SelectedTabChangedEventArgs e)
Infragistics4.Win.UltraWinTabControl.v22.2.DLL : N 00149
Infragistics.Win.UltraWinTabControl.UltraTabControlBase.RaiseEvent(UltraTabControlEventId id, EventArgs e)
Infragistics4.Win.UltraWinTabControl.v22.2.DLL : N 00562
Infragistics.Win.UltraWinTabControl.UltraTabControlBase.OnManagerSelectedTabItemChanged(Object sender, SelectedTabItemChangedEventArgs e)
Infragistics4.Win.UltraWinTabControl.v22.2.DLL : N 01090
Infragistics.Win.UltraWinTabs.TabManager.set_SelectedTabItem(ITabItem value)
Infragistics4.Win.v22.2.DLL : N 00306
Trimble.Vce.UI.BaseCommands.ExportCmdUI.OnLoad(EventArgs e)
Trimble.Vce.UI.BaseCommands.DLL : N 01733
System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
System.Windows.Forms.dll : N 00433
System.Windows.Forms.Control.CreateControl()
System.Windows.Forms.dll : N 00042
System.Windows.Forms.ControlCollection.Add(Control value)
System.Windows.Forms.dll : N 00912
Trimble.Vce.UI.CommandPaneFrame.fw(ICommand a, Boolean b)
Trimble.Vce.UI.Client.DLL : N 02054
Trimble.Vce.UI.CommandPaneFrame.ShowCommand(ICommand Command)
Trimble.Vce.UI.Client.DLL : N 00130
Trimble.Vce.UI.UIManager.CommandAdapter.Execute(Object parameter)
Trimble.Vce.UI.UIManager.DLL : N 00822
Trimble.Sdk.UI.UiCommandProcessor.c(String a, Boolean b, Boolean c, Object[] d)
Trimble.Sdk.UI.DLL : N 01993
Date and Time: 9/18/2025 4:52:14 PM
Machine Name: LAPTOP-IQDOA7C
IP Address: fe80::9714:c6fa:788f:9cb4%11, 192.168.1.9,
Current User: INDY\gcrawford
Application Domain: TrimbleBusinessCenter.exe
Thread Name: Office UI Thread
---- Assemblies in AppDomain ----
Assembly Full Name: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Assembly Full Name: TrimbleBusinessCenter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleBusinessCenter.exe
Assembly Full Name: CrowdStrike.Sensor.ScriptControl, Version=7.27.19907.0, Culture=neutral, PublicKeyToken=02b60967b1f68187
Assembly Codebase: file:///C:/WINDOWS/assembly/GAC_MSIL/CrowdStrike.Sensor.ScriptControl/7.27.19907.0__02b60967b1f68187/CrowdStrike.Sensor.ScriptControl.dll
Assembly Full Name: Trimble.Vce.UI.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.DLL
Assembly Full Name: System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Assembly Full Name: System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Assembly Full Name: System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Assembly Full Name: System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Assembly Full Name: Trimble.Vce.UI.UIManager, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.DLL
Assembly Full Name: Trimble.Sdk.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Interfaces.DLL
Assembly Full Name: Trimble.Sdk.DiskIO, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.DiskIO.DLL
Assembly Full Name: netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/netstandard/v4.0_2.0.0.0__cc7b13ffcd2ddd51/netstandard.dll
Assembly Full Name: Microsoft.Extensions.Configuration.Abstractions, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.Abstractions.DLL
Assembly Full Name: Trimble.Vce.UI.Client, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.DLL
Assembly Full Name: System.ValueTuple, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.ValueTuple.DLL
Assembly Full Name: System.Reactive, Version=6.0.0.0, Culture=neutral, PublicKeyToken=94bc3704cddfc263
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.DLL
Assembly Full Name: System.Text.Json, Version=9.0.0.4, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Text.Json.DLL
Assembly Full Name: System.Threading.Tasks.Extensions, Version=4.2.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Threading.Tasks.Extensions.DLL
Assembly Full Name: Trimble.Sdk.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.UI.DLL
Assembly Full Name: System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Assembly Full Name: System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Assembly Full Name: Microsoft.Extensions.Configuration, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.DLL
Assembly Full Name: Microsoft.Extensions.Configuration.FileExtensions, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.FileExtensions.DLL
Assembly Full Name: Microsoft.Extensions.Configuration.Json, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.Json.DLL
Assembly Full Name: Microsoft.Extensions.FileProviders.Abstractions, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.FileProviders.Abstractions.DLL
Assembly Full Name: Microsoft.Extensions.FileProviders.Physical, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.FileProviders.Physical.DLL
Assembly Full Name: Microsoft.Extensions.Primitives, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Primitives.DLL
Assembly Full Name: System.Memory, Version=4.0.5.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Memory.DLL
Assembly Full Name: System.Runtime.CompilerServices.Unsafe, Version=6.0.3.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Runtime.CompilerServices.Unsafe.DLL
Assembly Full Name: System.Buffers, Version=4.0.5.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Buffers.DLL
Assembly Full Name: System.IO.Pipelines, Version=9.0.0.4, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.IO.Pipelines.DLL
Assembly Full Name: System.Numerics.Vectors, Version=4.1.6.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Numerics.Vectors.DLL
Assembly Full Name: Trimble.Vce.UI.BaseCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.DLL
Assembly Full Name: Infragistics4.Win.UltraWinToolbars.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinToolbars.v22.2.DLL
Assembly Full Name: Trimble.Sdk, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.DLL
Assembly Full Name: Newtonsoft.Json, Version=13.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Newtonsoft.Json.DLL
Assembly Full Name: Trimble.Vce.TbcLicense, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.TbcLicense.DLL
Assembly Full Name: Trimble.Vce.Services.Tbc, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tbc.DLL
Assembly Full Name: Trimble.Vce.Services.Auth, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Auth.DLL
Assembly Full Name: Trimble.Sdk.FeatureExtraction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.FeatureExtraction.DLL
Assembly Full Name: Trimble.Sdk.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Core.DLL
Assembly Full Name: Trimble.Sdk.Persistence, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Persistence.DLL
Assembly Full Name: NLog, Version=5.0.0.0, Culture=neutral, PublicKeyToken=5120e14c03d0593c
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NLog.DLL
Assembly Full Name: Trimble.Trdm.ServiceManagement, Version=2.25.2.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Trdm.ServiceManagement.DLL
Assembly Full Name: Loupe.Agent.NETCore, Version=5.0.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Agent.NETCore.DLL
Assembly Full Name: Loupe.Core.NETCore, Version=5.0.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Core.NETCore.DLL
Assembly Full Name: Loupe.Extensibility.NETCore, Version=5.0.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Extensibility.NETCore.DLL
Assembly Full Name: Trimble.ID, Version=1.2.1.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.ID.DLL
Assembly Full Name: Trimble.ID.Desktop, Version=1.1.1.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.ID.Desktop.DLL
Assembly Full Name: Trimble.Sdk.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Utilities.DLL
Assembly Full Name: TCPAnalyticsSDK, Version=1.2.1.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TCPAnalyticsSDK.DLL
Assembly Full Name: System.Net.Http, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
Assembly Full Name: System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Assembly Full Name: System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Assembly Full Name: System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Assembly Full Name: TrimbleCloud.Common.Logging, Version=3.0.2.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleCloud.Common.Logging.DLL
Assembly Full Name: TrimbleCloud.Common, Version=3.1.1.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleCloud.Common.DLL
Assembly Full Name: System.Security.Cryptography.ProtectedData, Version=7.0.0.1, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Security.Cryptography.ProtectedData.DLL
Assembly Full Name: System.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
Assembly Full Name: Microsoft.Extensions.Logging.Abstractions, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Logging.Abstractions.DLL
Assembly Full Name: Microsoft.Extensions.Logging, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Logging.DLL
Assembly Full Name: Microsoft.Extensions.Options, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Options.DLL
Assembly Full Name: Infragistics4.Win.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.v22.2.DLL
Assembly Full Name: Trimble.ExternalService.Core, Version=1.5.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.ExternalService.Core.DLL
Assembly Full Name: Trimble.Vce.DeviceIo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.DLL
Assembly Full Name: Microsoft.Extensions.DependencyInjection.Abstractions, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.DependencyInjection.Abstractions.DLL
Assembly Full Name: Microsoft.AspNetCore.SignalR.Client.Core, Version=8.0.11.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Client.Core.DLL
Assembly Full Name: Microsoft.Bcl.AsyncInterfaces, Version=9.0.0.4, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Bcl.AsyncInterfaces.DLL
Assembly Full Name: Microsoft.AspNetCore.SignalR.Common, Version=8.0.11.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Common.DLL
Assembly Full Name: ReactiveUI, Version=19.5.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/ReactiveUI.DLL
Assembly Full Name: WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
Assembly Full Name: Microsoft.AspNetCore.SignalR.Client, Version=8.0.11.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Client.DLL
Assembly Full Name: System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Assembly Full Name: Microsoft.AspNetCore.Http.Connections.Common, Version=8.0.11.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Http.Connections.Common.DLL
Assembly Full Name: Splat, Version=14.8.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Splat.DLL
Assembly Full Name: Microsoft.AspNetCore.SignalR.Protocols.Json, Version=8.0.11.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Protocols.Json.DLL
Assembly Full Name: Microsoft.AspNetCore.Connections.Abstractions, Version=8.0.11.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Connections.Abstractions.DLL
Assembly Full Name: Microsoft.AspNetCore.Http.Connections.Client, Version=8.0.11.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Http.Connections.Client.DLL
Assembly Full Name: Microsoft.Extensions.DependencyInjection, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.DependencyInjection.DLL
Assembly Full Name: ReactiveUI.Wpf, Version=19.5.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/ReactiveUI.Wpf.DLL
Assembly Full Name: PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
Assembly Full Name: PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
Assembly Full Name: System.Text.Encodings.Web, Version=9.0.0.4, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Text.Encodings.Web.DLL
Assembly Full Name: System.Threading.Channels, Version=8.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Threading.Channels.DLL
Assembly Full Name: Microsoft.Extensions.Features, Version=8.0.11.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Features.DLL
Assembly Full Name: System.Runtime.InteropServices.RuntimeInformation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.InteropServices.RuntimeInformation/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.InteropServices.RuntimeInformation.dll
Assembly Full Name: Trimble.Sdk.Serialization, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Serialization.DLL
Assembly Full Name: jose-jwt, Version=5.0.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/jose-jwt.DLL
Assembly Full Name: System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.Extensions.dll
Assembly Full Name: System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Assembly Full Name: Trimble.Licensing.Portable, Version=2.27.203.0, Culture=neutral, PublicKeyToken=b7f8a478d680afaf
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Licensing.Portable.DLL
Assembly Full Name: System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.dll
Assembly Full Name: Trimble.Licensing.Windows, Version=2.27.203.0, Culture=neutral, PublicKeyToken=b7f8a478d680afaf
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Licensing.Windows.DLL
Assembly Full Name: LicensingV2WinCLRBridge, Version=1.0.8235.28111, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/LicensingV2WinCLRBridge.DLL
Assembly Full Name: System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Assembly Full Name: Infragistics4.Shared.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Shared.v22.2.DLL
Assembly Full Name: Infragistics4.Win.Misc.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.Misc.v22.2.DLL
Assembly Full Name: UIAutomationProvider, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Assembly Full Name: UIAutomationTypes, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
Assembly Full Name: Autofac, Version=7.1.0.0, Culture=neutral, PublicKeyToken=17863af14b0044da
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Autofac.DLL
Assembly Full Name: Trimble.Sdk.Geometry, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Geometry.DLL
Assembly Full Name: Trimble.Vce.Data.Machine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Machine.DLL
Assembly Full Name: Trimble.Sdk.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.SCS.DLL
Assembly Full Name: Trimble.CoreX.CSD, Version=2.91.19.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.CoreX.CSD.DLL
Assembly Full Name: Trimble.Vce.InjectDependencies, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.InjectDependencies.DLL
Assembly Full Name: Trimble.Sdk.ConfigurationInterfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.ConfigurationInterfaces.DLL
Assembly Full Name: Trimble.Sdk.Configuration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Configuration.DLL
Assembly Full Name: Trimble.Geodetic.AdaptorLibraryConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.AdaptorLibraryConfiguration.DLL
Assembly Full Name: Trimble.Geodetic.OpticalLibraryConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.OpticalLibraryConfiguration.DLL
Assembly Full Name: Trimble.Geodetic.LeapSecondsConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.LeapSecondsConfiguration.DLL
Assembly Full Name: Trimble.GNSS.SatelliteSystemsConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.GNSS.SatelliteSystemsConfiguration.DLL
Assembly Full Name: Trimble.DefaultLegalDescriptionConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.DefaultLegalDescriptionConfiguration.DLL
Assembly Full Name: Trimble.LandXMLToGenio.ConverterConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.LandXMLToGenio.ConverterConfiguration.DLL
Assembly Full Name: Autofac.Extensions.DependencyInjection, Version=8.0.0.0, Culture=neutral, PublicKeyToken=17863af14b0044da
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Autofac.Extensions.DependencyInjection.DLL
Assembly Full Name: Loupe.Extensions.Logging, Version=5.0.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Extensions.Logging.DLL
Assembly Full Name: Trimble.Sdk.Units, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Units.DLL
Assembly Full Name: Trimble.Sdk.Primitives, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Primitives.DLL
Assembly Full Name: Trimble.Sdk.Properties, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Properties.DLL
Assembly Full Name: Trimble.Sdk.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Features.DLL
Assembly Full Name: Trimble.Sdk.FeatureDefinitions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.FeatureDefinitions.DLL
Assembly Full Name: Trimble.Sdk.RawData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.RawData.DLL
Assembly Full Name: Roc.Common.Symphony, Version=5.0.1.1, Culture=neutral, PublicKeyToken=205c53175e304905
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Roc.Common.Symphony.DLL
Assembly Full Name: Trimble.Vce.Data.Import, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Import.DLL
Assembly Full Name: Trimble.Vce.MobileMapping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.MobileMapping.DLL
Assembly Full Name: Microsoft.Practices.Prism.Mvvm, Version=1.1.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.Prism.Mvvm.DLL
Assembly Full Name: System.Resources.ResourceManager, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Resources.ResourceManager/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Resources.ResourceManager.dll
Assembly Full Name: System.ObjectModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ObjectModel/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ObjectModel.dll
Assembly Full Name: EntityFramework, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/EntityFramework.DLL
Assembly Full Name: log4net, Version=2.0.17.0, Culture=neutral, PublicKeyToken=669e0ddf0bb1aa2a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/log4net.DLL
Assembly Full Name: Trimble.Vce.Epm, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Epm.DLL
Assembly Full Name: Trimble.Sdk.MobileMapping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.MobileMapping.DLL
Assembly Full Name: System.Drawing.Common, Version=8.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Drawing.Common.DLL
Assembly Full Name: Mxips.NET, Version=2.1.8167.30381, Culture=neutral, PublicKeyToken=e789022f6ecb484d
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Mxips.NET.DLL
Assembly Full Name: TISProcess.Net, Version=3.9.0.11380, Culture=neutral, PublicKeyToken=2afac910f877cde3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TISProcess.Net.DLL
Assembly Full Name: Sde.NET, Version=3.9.0.11380, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Sde.NET.DLL
Assembly Full Name: Trimble.Vce.Data.REB, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.REB.DLL
Assembly Full Name: Trimble.Vce.FeatureExtraction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.FeatureExtraction.DLL
Assembly Full Name: Trimble.eCognition.Engine, Version=10.5.1.736, Culture=neutral, PublicKeyToken=642a35afe50921e5
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.eCognition.Engine.DLL
Assembly Full Name: Sdm.NET, Version=3.9.0.11380, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Sdm.NET.DLL
Assembly Full Name: Trimble.Sdk.Coordinates, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Coordinates.DLL
Assembly Full Name: Trimble.Vce.Data.SDE, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SDE.DLL
Assembly Full Name: Trimble.Vce.ReportEngine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ReportEngine.DLL
Assembly Full Name: Trimble.Vce.UI.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Reports.DLL
Assembly Full Name: Trimble.Vce.ViewModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ViewModel.DLL
Assembly Full Name: Trimble.Vce.GraphicsEngine2D, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GraphicsEngine2D.DLL
Assembly Full Name: Trimble.Vis.PdfImporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.PdfImporter.DLL
Assembly Full Name: Trimble.Vce.Data.LandXML, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.LandXML.DLL
Assembly Full Name: Trimble.Sdk.Alignment, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Alignment.DLL
Assembly Full Name: Trimble.Sdk.UI.Commands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.UI.Commands.DLL
Assembly Full Name: Trimble.Vce.ConnectedWorkspace, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ConnectedWorkspace.DLL
Assembly Full Name: Trimble.Scs.LocalDatasetWorkspaces.ProtoGenerated, Version=1.0.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Scs.LocalDatasetWorkspaces.ProtoGenerated.DLL
Assembly Full Name: Google.Protobuf, Version=3.28.2.0, Culture=neutral, PublicKeyToken=a7d26565bac4d604
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Google.Protobuf.DLL
Assembly Full Name: Trimble.Sdk.Data, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Data.DLL
Assembly Full Name: Trimble.Sdk.Surface, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Surface.DLL
Assembly Full Name: Trimble.Vce.ComputationEngine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ComputationEngine.DLL
Assembly Full Name: CommunityToolkit.Mvvm, Version=8.3.0.0, Culture=neutral, PublicKeyToken=4aff67a105548ee2
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/CommunityToolkit.Mvvm.DLL
Assembly Full Name: Trimble.Vce.UI.Wpf, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wpf.DLL
Assembly Full Name: CefSharp, Version=135.0.170.0, Culture=neutral, PublicKeyToken=40c4b6fc221f4138
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/CefSharp.DLL
Assembly Full Name: Infragistics4.Win.UltraWinDock.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDock.v22.2.DLL
Assembly Full Name: Trimble.Vce.UI.ScanningCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScanningCommands.DLL
Assembly Full Name: Trimble.Vce.Scanning, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Scanning.DLL
Assembly Full Name: Trimble.Vce.UI.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Hoops.DLL
Assembly Full Name: Microsoft.WindowsAPICodePack.Shell, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.Shell.DLL
Assembly Full Name: Infragistics4.Win.UltraWinTabbedMdi.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabbedMdi.v22.2.DLL
Assembly Full Name: BellbirdInterfaces, Version=1.1.6680.18676, Culture=neutral, PublicKeyToken=e46c466c63fb6536
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/BellbirdInterfaces.DLL
Assembly Full Name: System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Assembly Full Name: Trimble.Vce.Data.UASMaster, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.UASMaster.DLL
Assembly Full Name: Infragistics4.Win.UltraWinGrid.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinGrid.v22.2.DLL
Assembly Full Name: System.IO.Compression, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
Assembly Full Name: Trimble.Sdk.Scanning, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Scanning.DLL
Assembly Full Name: Trimble.Sdk.Results, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Results.DLL
Assembly Full Name: Trimble.Sdk.Cadastral, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Cadastral.DLL
Assembly Full Name: Trimble.Sdk.Cadastral.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Cadastral.Interfaces.DLL
Assembly Full Name: Trimble.Sdk.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Construction.DLL
Assembly Full Name: Trimble.Sdk.GNSSData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.GNSSData.DLL
Assembly Full Name: Trimble.Sdk.Math, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Math.DLL
Assembly Full Name: Trimble.Core.CSDUI.MVP, Version=4.0.1.0, Culture=neutral, PublicKeyToken=012f2610d490fd1a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.CSDUI.MVP.DLL
Assembly Full Name: Trimble.Core.CSD, Version=2.91.0.1, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.CSD.DLL
Assembly Full Name: Infragistics4.Win.UltraWinTree.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTree.v22.2.DLL
Assembly Full Name: Trimble.Vce.UI.Controls.PropertyGrid, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.PropertyGrid.DLL
Assembly Full Name: Infragistics4.Win.UltraWinEditors.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinEditors.v22.2.DLL
Assembly Full Name: Trimble.Sdk.ForeignCad, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.ForeignCad.DLL
Assembly Full Name: System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Assembly Full Name: WindowsFormsIntegration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
Assembly Full Name: Microsoft.Practices.EnterpriseLibrary.Validation, Version=6.0.0.0, Culture=neutral, PublicKeyToken=9d493c709b8014cc
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Validation.DLL
Assembly Full Name: Microsoft.Practices.EnterpriseLibrary.Common, Version=6.0.0.0, Culture=neutral, PublicKeyToken=9d493c709b8014cc
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Common.DLL
Assembly Full Name: Trimble.Vce.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hoops.DLL
Assembly Full Name: Trimble.Sdk.GraphicsModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.GraphicsModel.DLL
Assembly Full Name: hoops_mvo2720_cs141, Version=27.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hoops_mvo2720_cs141.DLL
Assembly Full Name: hics2720_cs141, Version=27.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hics2720_cs141.DLL
Assembly Full Name: hoops_stream2720_cs141, Version=27.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hoops_stream2720_cs141.DLL
Assembly Full Name: Trimble.Vce.Services.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Construction.DLL
Assembly Full Name: Trimble.Vce.GE.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Core.DLL
Assembly Full Name: Microsoft.Extensions.Configuration.Binder, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.Binder.DLL
Assembly Full Name: NTJV.UI.Commands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.UI.Commands.DLL
Assembly Full Name: NTJV.ViewModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.ViewModel.DLL
Assembly Full Name: Trimble.Vce.UI.MonitoringCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.MonitoringCommands.DLL
Assembly Full Name: Trimble.Vce.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Monitoring.DLL
Assembly Full Name: Trimble.Sdk.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Monitoring.DLL
Assembly Full Name: Trimble.Vce.Services.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Monitoring.DLL
Assembly Full Name: Trimble.Vce.UI.ConstructionCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionCommands.DLL
Assembly Full Name: Trimble.Vce.UI.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Construction.DLL
Assembly Full Name: Trimble.Vce.UI.ConstructionReports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionReports.DLL
Assembly Full Name: Trimble.Vce.Functions.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Functions.SCS.DLL
Assembly Full Name: Infragistics4.Win.UltraWinChart.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinChart.v22.2.DLL
Assembly Full Name: Infragistics4.Win.UltraWinListView.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinListView.v22.2.DLL
Assembly Full Name: Trimble.Vce.Services.Tcc, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tcc.DLL
Assembly Full Name: TrimbleGeospatial.ScandataServices.Sdk, Version=3.5.6.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleGeospatial.ScandataServices.Sdk.DLL
Assembly Full Name: System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Caching/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Caching.dll
Assembly Full Name: Trimble.Vce.Data.JobXML, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.JobXML.DLL
Assembly Full Name: Trimble.Vce.Data.RXL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.RXL.DLL
Assembly Full Name: Trimble.Vce.Data.GeneralSurvey, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GeneralSurvey.DLL
Assembly Full Name: Microsoft.Win32.Registry, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Win32.Registry.DLL
Assembly Full Name: Microsoft.Extensions.Http, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Http.DLL
Assembly Full Name: Trimble.Sdk.PlatformServices, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.PlatformServices.DLL
Assembly Full Name: NTJV.Data.Converter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.Data.Converter.DLL
Assembly Full Name: Trimble.Vce.Data.DWG, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DWG.DLL
Assembly Full Name: OdSwig_TD_RootIntegrated_Mgd, Version=25.12.0.0, Culture=neutral, PublicKeyToken=f5bc3941bdf0edcd
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/OdSwig_TD_RootIntegrated_Mgd.DLL
Assembly Full Name: OdSwig_TD_DbCoreIntegrated_Mgd, Version=25.12.0.0, Culture=neutral, PublicKeyToken=cb788abe0db5f46a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/OdSwig_TD_DbCoreIntegrated_Mgd.DLL
Assembly Full Name: Trimble.Vce.Data.GIS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GIS.DLL
Assembly Full Name: DataInteroperabilityComponent, Version=1.7.0.26, Culture=neutral, PublicKeyToken=3c2e0c2def562052
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/DataInteroperabilityComponent.DLL
Assembly Full Name: Trimble.Penmap.IDiagnostics, Version=1.0.0.0, Culture=neutral, PublicKeyToken=dabc04b9c91d084c
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Penmap.IDiagnostics.DLL
Assembly Full Name: Trimble.Penmap.IFolderProvider, Version=1.0.0.0, Culture=neutral, PublicKeyToken=dabc04b9c91d084c
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Penmap.IFolderProvider.DLL
Assembly Full Name: Microsoft.ReportViewer.WinForms, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.WinForms.DLL
Assembly Full Name: Trimble.VCE.Data.IFC, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.IFC.DLL
Assembly Full Name: Trimble.Technology.TrimBim, Version=2.32.0.0, Culture=neutral, PublicKeyToken=93c0f7e4f1ca9619
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Technology.TrimBim.DLL
Assembly Full Name: Tekla.Common.Geometry.Primitives, Version=4.5.0.0, Culture=neutral, PublicKeyToken=93c0f7e4f1ca9619
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Tekla.Common.Geometry.Primitives.DLL
Assembly Full Name: IfcExportSDK2.Interop, Version=6.1.2.0, Culture=neutral, PublicKeyToken=c468c97453e54754
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IfcExportSDK2.Interop.DLL
Assembly Full Name: Trimble.Vce.Data.ReceiverRaw, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ReceiverRaw.DLL
Assembly Full Name: Trimble.Vce.Data.ScJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ScJob.DLL
Assembly Full Name: Trimble.Vce.Data.FieldBookJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.FieldBookJob.DLL
Assembly Full Name: Trimble.Vce.Data.MercuryJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.MercuryJob.DLL
Assembly Full Name: Trimble.Vce.Data.TDS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TDS.DLL
Assembly Full Name: Trimble.Vce.Data.SpJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SpJob.DLL
Assembly Full Name: Trimble.Vce.Data.TDE, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TDE.DLL
Assembly Full Name: Trimble.Vce.Data.NGSDataSheet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.NGSDataSheet.DLL
Assembly Full Name: Trimble.Vce.Data.DC, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DC.DLL
Assembly Full Name: Trimble.Vce.Data.Custom, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Custom.DLL
Assembly Full Name: OdSwig_AecBase_Mgd, Version=25.12.0.0, Culture=neutral, PublicKeyToken=e6b57afb968ce91d
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/OdSwig_AecBase_Mgd.DLL
Assembly Full Name: Trimble.Sdk.SurveyCAD, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.SurveyCAD.DLL
Assembly Full Name: Trimble.Sdk.CompositeEntities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.CompositeEntities.DLL
Assembly Full Name: Trimble.Vce.Data.TTM, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TTM.DLL
Assembly Full Name: Trimble.Vce.Data.Moss, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Moss.DLL
Assembly Full Name: Trimble.Vce.Data.SCSResults, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SCSResults.DLL
Assembly Full Name: Trimble.SPJLib, Version=1.51.23100.241, Culture=neutral, PublicKeyToken=36d9a2a67ff4b07d
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.SPJLib.DLL
Assembly Full Name: Trimble.HCC.TBC.Intefaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=0c98c1339e2d36f4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.HCC.TBC.Intefaces.DLL
Assembly Full Name: Trimble.HCC.TBC.NoteLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=0c98c1339e2d36f4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.HCC.TBC.NoteLib.DLL
Assembly Full Name: Trimble.Vce.Data.M5, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.M5.DLL
Assembly Full Name: Trimble.Vce.Data.OPUSSolution, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.OPUSSolution.DLL
Assembly Full Name: Trimble.Vce.Data.RTXSolution, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.RTXSolution.DLL
Assembly Full Name: Trimble.Vce.Data.Zip, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Zip.DLL
Assembly Full Name: Trimble.Vce.Data.GeoRefImage, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GeoRefImage.DLL
Assembly Full Name: Trimble.Vce.Data.KOF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.KOF.DLL
Assembly Full Name: Trimble.Vce.Data.SBG, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Sbg.DLL
Assembly Full Name: Trimble.Vce.ISTRAMimporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ISTRAMimporter.DLL
Assembly Full Name: Trimble.Vce.Data.FXL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.FXL.DLL
Assembly Full Name: Trimble.Vce.Data.Ashtech, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Ashtech.DLL
Assembly Full Name: Trimble.Vce.Data.AshtechJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.AshtechJob.DLL
Assembly Full Name: Trimble.Vce.Data.Skp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Skp.DLL
Assembly Full Name: Trimble.Vce.Data.Novapoint, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Novapoint.DLL
Assembly Full Name: Trimble.Vce.Data.VCL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.VCL.DLL
Assembly Full Name: Trimble.Vce.Data.IModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.IModel.DLL
Assembly Full Name: Bentley.DesignSync.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9bfed12b64a9b7df
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.DesignSync.Interfaces.DLL
Assembly Full Name: Trimble.Vce.Data.Kml, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.KML.DLL
Assembly Full Name: Trimble.Vis.Tools, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.Tools.DLL
Assembly Full Name: Trimble.Vce.Data.ImageProcessing, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ImageProcessing.DLL
Assembly Full Name: Trimble.Vce.Data.PythonImporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.PythonImporter.DLL
Assembly Full Name: Trimble.Vce.Data.SSF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SSF.DLL
Assembly Full Name: Trimble.Vce.Data.TXL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TXL.DLL
Assembly Full Name: Trimble.Vce.Data.DJI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DJI.DLL
Assembly Full Name: TBCWebApi.Client.Shared, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TBCWebApi.Client.Shared.DLL
Assembly Full Name: Trimble.eCog.API, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.eCog.API.DLL
Assembly Full Name: Trimble.Vce.GE.Imaging.Gdal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Imaging.Gdal.DLL
Assembly Full Name: Trimble.Vce.Services.Tunneling, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tunneling.DLL
Assembly Full Name: Trimble.MonSol.ClientLib, Version=1.12.0.0, Culture=neutral, PublicKeyToken=76a11225be98aa56
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.MonSol.ClientLib.DLL
Assembly Full Name: Anonymously Hosted DynamicMethods Assembly, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name: Grpc.Core.Api, Version=2.0.0.0, Culture=neutral, PublicKeyToken=d754f35622e28bad
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Grpc.Core.Api.DLL
Assembly Full Name: Loupe.Agent.Core.Services, Version=5.0.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Agent.Core.Services.DLL
Assembly Full Name: System.Diagnostics.DiagnosticSource, Version=9.0.0.4, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Diagnostics.DiagnosticSource.DLL
Assembly Full Name: System.ComponentModel.Composition, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.Composition/v4.0_4.0.0.0__b77a5c561934e089/System.ComponentModel.Composition.dll
Assembly Full Name: SkiaSharp, Version=2.88.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/SkiaSharp.DLL
Assembly Full Name: CsdManagementWrapper, Version=4.3.55.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/CsdManagementWrapper.DLL
Assembly Full Name: GeodeticXWrapper, Version=4.3.55.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/GeodeticXWrapper.DLL
Assembly Full Name: Trimble.CoreX.Gdtic, Version=4.60.101.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.CoreX.Gdtic.DLL
Assembly Full Name: Trimble.Sdk.Geodetic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Geodetic.DLL
Assembly Full Name: System.Resources.Extensions, Version=8.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Resources.Extensions.DLL
Assembly Full Name: Trimble.Sdk.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Reports.DLL
Assembly Full Name: System.ComponentModel.DataAnnotations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
Assembly Full Name: Infragistics4.Win.UltraWinStatusBar.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinStatusBar.v22.2.DLL
Assembly Full Name: Microsoft.WindowsAPICodePack, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.DLL
Assembly Full Name: Infragistics4.Win.UltraWinExplorerBar.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinExplorerBar.v22.2.DLL
Assembly Full Name: Trimble.Trdm.Contracts, Version=2.25.2.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Trdm.Contracts.DLL
Assembly Full Name: INIFileParser, Version=2.5.2.0, Culture=neutral, PublicKeyToken=79af7b307b65cf3c
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/INIFileParser.DLL
Assembly Full Name: Trimble.Vce.Share, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.dll
Assembly Full Name: Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Assembly Full Name: NTJV.UI.CracksControl, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.UI.CracksControl.DLL
Assembly Full Name: Trimble.Vce.UI.Wrapper, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wrapper.DLL
Assembly Full Name: Trimble.Vce.UI.GNSS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.GNSS.DLL
Assembly Full Name: Trimble.Vce.UI.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.SCS.DLL
Assembly Full Name: Trimble.Vce.UI.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Monitoring.DLL
Assembly Full Name: Trimble.Vce.UI.PPCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.PPCommands.DLL
Assembly Full Name: Trimble.Vce.UI.ScsCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScsCommands.DLL
Assembly Full Name: Trimble.SCS_WorkOrder, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.SCS_WorkOrder.DLL
Assembly Full Name: Trimble.Vce.UI.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Features.DLL
Assembly Full Name: Trimble.Vce.UI.INetDownload, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.INetDownload.DLL
Assembly Full Name: IdentityModel.OidcClient, Version=5.0.0.0, Culture=neutral, PublicKeyToken=5580d04c1b6c37c1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IdentityModel.OidcClient.DLL
Assembly Full Name: Trimble.Vce.UI.CoreCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.CoreCommands.DLL
Assembly Full Name: Trimble.Vis.UI.TccCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.TccCommands.DLL
Assembly Full Name: Trimble.Vis.UI.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.Core.DLL
Assembly Full Name: Trimble.Vis.UI.PdfCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.PdfCommands.DLL
Assembly Full Name: Takeoff.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.UI.DLL
Assembly Full Name: Takeoff.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.Reports.DLL
Assembly Full Name: TBCWebApi.Basic.Shared, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TBCWebApi.Basic.Shared.DLL
Assembly Full Name: DynamicData, Version=8.3.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/DynamicData.DLL
Assembly Full Name: Trimble.MonSol.HttpApiClient, Version=1.15.0.0, Culture=neutral, PublicKeyToken=76a11225be98aa56
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.MonSol.HttpApiClient.DLL
Assembly Full Name: AutoMapper, Version=10.0.0.0, Culture=neutral, PublicKeyToken=be96cd2c38ef1005
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/AutoMapper.DLL
Assembly Full Name: System.Configuration.ConfigurationManager, Version=8.0.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Configuration.ConfigurationManager.DLL
Assembly Full Name: Trimble.ExternalService.API.Client, Version=1.5.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.ExternalService.API.Client.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.dll
Assembly Full Name: Microsoft.Scripting, Version=1.3.5.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Scripting.DLL
Assembly Full Name: IronPython, Version=3.4.2.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.DLL
Assembly Full Name: Microsoft.Dynamic, Version=1.3.5.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Dynamic.DLL
Assembly Full Name: IronPython.Modules, Version=3.4.2.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.Modules.DLL
Assembly Full Name: Snippets.scripting, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name: MediatR, Version=9.0.0.0, Culture=neutral, PublicKeyToken=bb9a41a5e8aaa7e2
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/MediatR.DLL
Assembly Full Name: Trimble.Sdk.COGO, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.COGO.DLL
Assembly Full Name: System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Discovery/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Discovery.dll
Assembly Full Name: System.ServiceModel.Internals, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
Assembly Full Name: SMDiagnostics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
Assembly Full Name: System.IdentityModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
Assembly Full Name: Trimble.Vce.ComputationEngine.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ComputationEngine.Core.DLL
Assembly Full Name: Microsoft.Extensions.ObjectPool, Version=8.0.12.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.ObjectPool.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.UI.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.CoreCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Features.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.INetDownload.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.PPCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScanningCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScsCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.TccCommands.dll
Assembly Full Name: Microsoft.CSharp, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
Assembly Full Name: RPSShim, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands3/RockpileSolutions/RPSShim.pydll
Assembly Full Name: IronPython.Wpf, Version=3.4.2.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.Wpf.DLL
Assembly Full Name: System.Windows, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Windows.dll
Assembly Full Name: RockpileCustomControls, Version=2025.3000.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands3/RockpileSolutions/RockpileCustomControls.dll
Assembly Full Name: RPSUtilities, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands3/RockpileSolutions/RPSUtilities.pydll
Assembly Full Name: TMLValidation, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands3/RockpileSolutions/TMLValidation.pydll
Assembly Full Name: InfragisticsWPF4.Documents.Excel.v22.2, Version=22.2.20222.19, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/InfragisticsWPF4.Documents.Excel.v22.2.DLL
Assembly Full Name: InfragisticsWPF4.Documents.Core.v22.2, Version=22.2.20222.19, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/InfragisticsWPF4.Documents.Core.v22.2.DLL
Assembly Full Name: InfragisticsWPF4.Controls.Grids.XamSpreadsheet.v22.2, Version=22.2.20222.19, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/InfragisticsWPF4.Controls.Grids.XamSpreadsheet.v22.2.DLL
Assembly Full Name: InfragisticsWPF4.v22.2, Version=22.2.20222.19, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/InfragisticsWPF4.v22.2.DLL
Assembly Full Name: InfragisticsWPF4.Undo.v22.2, Version=22.2.20222.19, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/InfragisticsWPF4.Undo.v22.2.DLL
Assembly Full Name: System.EnterpriseServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
Assembly Full Name: System.Runtime.DurableInstancing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.DurableInstancing/v4.0_4.0.0.0__31bf3856ad364e35/System.Runtime.DurableInstancing.dll
Assembly Full Name: MenuManager, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands3/RockpileSolutions/Commands/MenuManager.pydll
Assembly Full Name: RPSNavigate, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands3/RockpileSolutions/Commands/RPSNavigate.pydll
Assembly Full Name: RPSSettings, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands3/RockpileSolutions/Commands/RPSSettings.pydll
Assembly Full Name: VoiceCommand, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands3/RockpileSolutions/Commands/VoiceCommand.pydll
Assembly Full Name: System.Speech, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
Assembly Full Name: Infragistics4.Win.SupportDialogs.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.SupportDialogs.v22.2.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleBusinessCenter.exe
Assembly Full Name: Trimble.Vce.Services.WeoGeo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.WeoGeo.DLL
Assembly Full Name: Trimble.Vce.Services.Bentley, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Bentley.DLL
Assembly Full Name: Trimble.IS.IPPxGate, Version=6.1.0.0, Culture=neutral, PublicKeyToken=62f2fc89c40229e7
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.IS.IPPxGate.DLL
Assembly Full Name: System.ServiceModel.Channels, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Channels/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Channels.dll
Assembly Full Name: System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
Assembly Full Name: System.Data.SqlXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.SqlXml/v4.0_4.0.0.0__b77a5c561934e089/System.Data.SqlXml.dll
Assembly Full Name: System.Transactions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
Assembly Full Name: System.Web.Services, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Assembly Full Name: System.Data.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Linq.dll
Assembly Full Name: System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.ApplicationServices/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.ApplicationServices.dll
Assembly Full Name: System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Activation/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Activation.dll
Assembly Full Name: Microsoft.Build.Framework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.Build.Framework/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.Build.Framework.dll
Assembly Full Name: System.Drawing.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
Assembly Full Name: Microsoft.Extensions.FileSystemGlobbing, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.FileSystemGlobbing.DLL
Assembly Full Name: Trimble.WPD.Combined, Version=1.0.0.0, Culture=neutral, PublicKeyToken=e3cd747afe5c1369
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.WPD.Combined.DLL
Assembly Full Name: Microsoft.Practices.Prism.SharedInterfaces, Version=1.1.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.Prism.SharedInterfaces.DLL
Assembly Full Name: System.Threading.Tasks, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Threading.Tasks/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Threading.Tasks.dll
Assembly Full Name: Trimble.Tdx, Version=3.9.0.11380, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Tdx.DLL
Assembly Full Name: Sdo.NET, Version=3.9.0.11380, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Sdo.NET.DLL
Assembly Full Name: System.Configuration.Install, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration.Install/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll
Assembly Full Name: System.Data.DataSetExtensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
Assembly Full Name: Microsoft.Extensions.Http.Polly, Version=8.0.6.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Http.Polly.DLL
Assembly Full Name: Azure.Storage.DataMovement, Version=12.0.0.0, Culture=neutral, PublicKeyToken=92742159e12e44c8
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Azure.Storage.DataMovement.DLL
Assembly Full Name: Microsoft.ReportViewer.Common, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.Common.DLL
Assembly Full Name: FlatBuffers, Version=1.12.0.0, Culture=neutral, PublicKeyToken=93c0f7e4f1ca9619
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/FlatBuffers.DLL
Assembly Full Name: Tekla.Common.Geometry.Shapes, Version=4.6.2.0, Culture=neutral, PublicKeyToken=93c0f7e4f1ca9619
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Tekla.Common.Geometry.Shapes.DLL
Assembly Full Name: Bentley.Geometry.2.0, Version=2.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.Geometry.2.0.DLL
Assembly Full Name: Bentley.ECExchange, Version=1.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.ECExchange.DLL
Assembly Full Name: Bentley.ECObjects.2.0, Version=2.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.ECObjects.2.0.DLL
Assembly Full Name: Trimble.Vce.ParallelComputer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ParallelComputer.DLL
Assembly Full Name: Microsoft.Extensions.Hosting.Abstractions, Version=9.0.0.4, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Hosting.Abstractions.DLL
Assembly Full Name: IdentityModel, Version=5.2.0.0, Culture=neutral, PublicKeyToken=e7877f4675df049f
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IdentityModel.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.dll
Assembly Full Name: Infragistics4.Win.UltraWinSchedule.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinSchedule.v22.2.DLL
Assembly Full Name: System.IO.Packaging, Version=8.0.0.1, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.IO.Packaging.DLL
Assembly Full Name: Trimble.Vce.InSphere.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.InSphere.Reports.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionReports.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.GNSS.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.Reports.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Reports.dll
Assembly Full Name: hoops2720_cs141, Version=27.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hoops2720_cs141.DLL
Assembly Full Name: System.Management, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Assembly Full Name: Trimble.Vce.GE.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Hoops.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hoops.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wrapper.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Construction.dll
Assembly Full Name: Infragistics4.Win.UltraWinDataSource.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDataSource.v22.2.DLL
Assembly Full Name: Infragistics4.Win.UltraWinTabControl.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabControl.v22.2.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.PropertyGrid.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.dll
Assembly Full Name: Trimble.Vce.Data.GeoNav, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Geonav.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.dll
Assembly Full Name: Trimble.Vce.Data.Trajectory, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Trajectory.DLL
Assembly Full Name: Trimble.Vce.Data.GPSeismic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GPSeismic.DLL
Assembly Full Name: Trimble.Vce.Data.Genio, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Genio.DLL
Assembly Full Name: Trimble.Vce.Data.SDMS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SDMS.DLL
Assembly Full Name: Trimble.Vce.Data.BlueBook, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Bluebook.DLL
Assembly Full Name: Trimble.Vce.Data.TMF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TMF.DLL
Assembly Full Name: Trimble.Vce.Data.Track, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Track.DLL
Assembly Full Name: Trimble.Vce.Data.SenseFly, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SenseFly.DLL
Assembly Full Name: TRBExporter, Version=25.10.113.0, Culture=neutral, PublicKeyToken=d8fd6ae012bed244
Assembly Codebase: file:///C:/Program Files/SiteVision AR Exporter/SiteVisionExport_25.1/TRBExporter.dll
Assembly Full Name: System.ServiceModel.Primitives, Version=8.1.2.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.ServiceModel.Primitives.DLL
Assembly Full Name: GppProxyEx2013, Version=4.7.10.0, Culture=neutral, PublicKeyToken=26c24350c55da050
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/GppProxyEx2013.DLL
Assembly Full Name: GppProxy2013, Version=4.7.10.0, Culture=neutral, PublicKeyToken=26c24350c55da050
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/GppProxy2013.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SDE.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TTM.dll
Assembly Full Name: dsaDqINcitzt, Version=0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.LandXML.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Machine.dll
Grady Crawford
