I have not had that problem. But I do have an Orthoimage export problem. I brought a metric Orthoimage.tiff into TBC (units set to metric) from Yellowscan/Cloudstation with no issues. I changed my TBC units to US feet and then Georeferenced the image. Then I exported the Orthoimage in US feet. I found, in the text file associated with the export, that the image was a metric export. This proved this to be the case when I tried to insert it into Virtual Surveyor as well. It ended up in lala land. Does anyone know how to export the image in US feet? I don't see a toggle or selection option that will allow it. Thank you for any help you can provide.
Tim Fox
Sent: 01-15-2025 07:26
Subject: Orthoimage export error
I have been having the same issue and can't get it to work. I hope an update will fix this issue soon.
Jason Gardner
