I put this on the Works OS community with no luck, so if anyone can clarify how, and or what we are exactly getting on the data outputs, that would be appreciated.
When exporting data from WorksOS, can I get some clarification on the point data I am seeing.
Are the points we extract for say (lowest pass) the centre of the bucket, the left / right side / both positions?
(If I look at the attached screen grab) there are a number of points from the excavators lowest pass.
The bucket on the excavator has a width to it, but we don't get a dual point location output. Therefore I assume we get a cleaned output based on the filter, and a background coded clearout of extraneous data?
i.e. in some trenching operations, I have seen a single point lowest pass location. (This effectively gives me a width of zero. I know that the bucket was 600mm wide, 900mm wide, etc, so any outputs from that single point aren't a true reflection on the bucket width) and hence overall volume would be reduced.
If anyone can shed some light on this it would be appreciated.
Kind Regards,
Julius
Julius Newman
