Polyline Error and Editing
  • 1.  Polyline Error and Editing
    Posted 09-01-2022 23:41
    I have created a poly line by joining a number of segments.
    When I try to offset this line, it creates a vague figure.
    It is obvious that there is some rogue segment somewhere in the polyline that needs editing.
    What is the way to zero-in on the rouge segment to edit the same.
    Attached PDF file gives the screen shots before and after offsetting the polyline.
    The zip file is the vce file. (vce file could not be uploaded !!!)
    Thanks for all help.
    Saif Bin Darwish
    Attachment(s)
    pdf
    Polyline Error.pdf   536 KB 1 version
    zip
    STB-08 Polyline Error.zip   67 KB 1 version
  • 2.  RE: Polyline Error and Editing
    Posted 09-02-2022 00:00
    Edited by Albert Olivier 09-02-2022 00:09
    Hi Saif Bin Darwish
    I checked you vce file and found quite a few areas where the offset has a problem, see the image attached. Will have a look to see if it will be possible to create an offset with this line.
    Albert Olivier
    TBC Technical Product Manager
  • 3.  RE: Polyline Error and Editing
    Posted 09-02-2022 00:06
    Here is the vce file.
    Thanks.
  • 4.  RE: Polyline Error and Editing
    Posted 09-02-2022 00:30
    Hi Saif
    I tested the offset and found that you can create and offset of 1.5m to the right and 0.5m to left that will work. The segments of you line are very short in some parts so when you create an offset where the lines have to cross over each other or it has to double back on itself to keep the line string as a one continues segment the "rogue" elements show up.
    Albert Olivier
  • 5.  RE: Polyline Error and Editing
    Posted 09-02-2022 00:39
    Thanks for the prompt response.
    I would like to know the easiest way to zero in on the rogue element / segment and edit the same.
    Thanks.
  • 6.  RE: Polyline Error and Editing
    Posted 09-02-2022 01:11
    Hi Saif
    You will have to check the whole line and where you see errors you can manually edit them. To do this select to offset line and right click, in the menu that pops up choose Edit. You will then be able to edit each segment of the line that you select, see my image below.
    Albert Olivier
  • 7.  RE: Polyline Error and Editing
    Posted 09-02-2022 01:16
    Thank you very much.
