Not sure how you've setup your Viewfilters. I've got one that is specifically for the Sheetview, that includes a layer where I put all my Dynaviews and it is usually locked.
The Dynaviews then have their own Viewfilter.
If you've got a similar setup you can try to go to the Advanced View Filter Settings for the Sheetview. Under Display Options set the following. It depends on your data having an elevation.
Sent: 06-20-2022 06:25
Subject: Printing settings
Unless they has been a recent change. You can not print in black and white. I heard there was suppose to a option for this and hav3 yet to see it. Best bet is to save and the change your draft work to white or black. You could also after printing the plot, open in Adobe and do a save as I think and you have an option for save in black and white.
Francisco Guerrero
