Hi Guy,
The service was reinstated last week. Apologies that I omitted to update that status.
The developer can see from the server logs that the processing service occasionally fails to accept a file and the system does not return any warning or error.
In these events they can also see that submitting the same file again a short time later works.
I do not have any better solution than to try resubmitting currently.
Chay
Chay Froggatt
Sent: 09-07-2021 08:49
Subject: Processing Services Upload not working
Chay,
I just retried sending a .t04 file to see if the service was working and have not received a reply email. Is the service still down?
GUY BIEN
Sent: 08-25-2021 13:43
Thank you Guy,
I can confirm the same and we have a developer looking into the updates required.
Chay
Chay Froggatt
Sent: 08-24-2021 17:34
I am having a different type of problem with the service. I am not receiving a solution from submitted T04 files. They are small, 737kb and 1316kb. Once I change the Measure method, I am unable to go to the next screen to chose the solution processor. If I do not change the method, I can move on, but no solution returns from the OPUS processor. Any suggestions?
GUY BIEN
Sent: 08-23-2021 19:36
Hi Ben,
I believe I understand what causes the error for your file as you mentioned it is 41Mb.
cloud.api.trimble.com is rejecting the file due to a recently introduced 10Mb upload limit. We are investigating how to work past this file size limit.
Jason,
I'm still not clear on what is triggering the failure on your file. Your screenshot indicates it is not the same cause as for Ben.
I'll invite you to a Connect project so that you can more easily send the file through to me.
Chay
Chay Froggatt
Sent: 08-23-2021 15:30
This is the file that keeps giving me the error. I have tried old files that I have used in the past and processed thru the TBC service and get the same Failed message. I was able to process this thru the NGS OPUS website.
Edit: I cannot attach the file due to it being a .21o extension. File is 41mb , so I cant send thru email.
ben lozolla
Sent: 08-23-2021 15:01
Hi Jason,
I am able to upload T02 files to the GNSS processor and cannot reproduce the screenshot that you initially uploaded.
Are you having difficulty with all T02 files or just this one?
Can you send me the specific T02 file and the url of the GNSSprocessor page you are uploading it to and I can try both here.
Chay
Chay Froggatt
Sent: 08-23-2021 04:15
Chay,
Does Trimble plan to have the GNSS processor fixed so that we can again upload TO2 files, or is this a deliberate change? We always have the ability to upload direct to an online processor like OPUS, but the feature in TBC is just so convenient when it works. Thanks for noticing the question and responding, I hope you are doing well.
Thanks,
Jason Weiss
Jason Weiss
Sent: 08-22-2021 14:07
The GNSS processor is successfully accepting T04 files currently.
If you are experiencing ongoing issues please submit the data files through your normal support channel.
Chay
Chay Froggatt
