Sean
I have encountered 2 different sets of conditions that have caused point cloud points to be missing:
1. In the project folder there is a "SdeDatabase.rwi file that contains a .rwcx file for each scan, I have had these go missing a few times, not sure why.
The solution I used is to reprocess the scan files in a fresh project and copy the files from the new "SdeDatabase.rwi file to replace the missing files.
As a preventive measure you can keep an extra copy of this file in your job.
2. The other time I have had points missing is when a point cloud region was accidentally deleted along with other features.
The solution is to select the point cloud on the default region, right click and select "Get All Points or Get Unused Points", this will restore the missing points to the default layer.
Hope this helps
John Whidden
Sent: 01-25-2022 13:46
Subject: Remaining scan data missing after Random subsampling
I think I have had similar issues with scan data disappearing. If you select the region and look at the properties does it say points zero? See the pic below. I have created surfaces from scan data and the surfaces are still there but the scan data is gone that created it.
Sean Lahann, PLS
Phoenix, Arizona
