Hi!
I would like to know that is there a way to import same surface (LandXML) more than two times
in TBC? I can import it first with "Triangle-based definition" and second time with
"Bot definitions (Use...)". If I try to import same surface again it won't import (because there are
already surface with a same name). I and our customers have to modify .LandXML file in notepad to change the surface name.
It would be handy if there was some kind of notification
"Surface with a same name already exist. Do you want to rename
imported surface?"
Or is there that kind of import-option for LandXML already?
Thank you!
Antti Niittyoja
