Hello Julius,
I've hacked a simple macro together.
Have a look if that does what you need. Works with CSV, JOB, JXL and so on as well.
As always, unzip into a subfolder in "C:\ProgramData\Trimble\MacroCommands" and restart TBC.
If you want the layer name to follow a different scheme (include a hyphen or the like) you need to edit line 247.
Sent: 03-14-2023 01:43
Subject: Select Feature
My workflow for this would be:
Open Project Explorer
Expand Imported Files tab
Right Click on your Work Order Import YYMMDD and Click Select Members
Go to the Home Tab and Open Advanced Select
Click Current Selection and Multiple Data Types (Or if it's just one data type you're after select that)
Go to the drop down menu below and select your prefered attribute select equal to/contains and add your search criteria.
I use this to isolate superceded drainage data from residential housing projects when I get a newer CAD layout, but it should also function for your purposes.
Matt
Matthew Pitt
