Set thickness in Site Improvements
  • 1.  Set thickness in Site Improvements
    Posted 12-21-2025 21:15
    Hi everyone, I hope you're all doing well. I have a question and would appreciate your help. I'm currently working on a take-off for a site renovation project.
    The asphalt pavement will be resurfaced over the existing asphalt, which means there is no fixed thickness.
    I have already created the original surface and the finished surface.
    I don't know how to set the thickness for the new asphalt layer, since Site Improvements only allows setting a fixed thickness.
    I'd be grateful for any support on this.
    Thank you very much!
    Thanh Hồ
  • 2.  RE: Set thickness in Site Improvements
    Posted 12-24-2025 04:58
    I have not seen a MSI for variable thickness.  You would just have to do a take off in a CORRIDOR.   Won't you have to remove the old hotmix and redo the subgrade?  Placing hotmix at variable depth would be a pain.
    Francisco Guerrero
