Sheet Set
  • 1.  Sheet Set
    Posted 08-21-2025 00:21
    Edited by Winus Aliya 08-21-2025 00:30
    I’m having an issue with elevation node labels in cross sections within my sheet set. When creating elevation node labels for the finished surface and existing ground, some chainages are not being labeled properly. Is there a way to fix this?
    For reference:
    • The bottom surface in the cross-section is the project surface.
    • The top surface is the existing ground (EG).
    Winus Aliya
  • 2.  RE: Sheet Set
    Posted 09-12-2025 01:36
    Or, is there at least a way to limit the amount of times this happens, in a new project this is happening to 1/10 stations, i understand that its because of the project surface being the way it is, but i can't really change it.
    Winus Aliya
