Siteworks will always have a DC file that should be able to be used directly by Access. Well, will have a DC file for jobs using a GNSS that were calibrated or using a published coordinate system.
Siteworks does not export JXLs...
The CAL file in Siteworks is only produced when an actual site calibration is performed. It is the same as the DC file but just contains more information on the point pairs used in the calibration procedure. But if you are using a published coordinate system Siteworks will only produce a DC, and that should be usable in TA.
Check out the attached document on how to do this. It's a bit dated since it's discussing SCS900, but the process and files have not changed between SCS900 and Siteworks relative to the calibration and DC files.
Steve DiBenedetto
Sent: 06-26-2022 15:17
Subject: Site calibration from Siteworks to Access
If you can export the calibration in either a JXL or DC file out of SiteWorks then you should be able to use import it into Trimble Access using the Create from JobXML or DC file option when creating a new job. Trimble Access doesn't directly support *.CAL files. However the *.CAL file format is based on the DC format. If you rename a *.CAL file to *.DC you might be able use it in TA.
James McWha
