I had my R12i, S7 & TSC5 delivered today. I need to set up the feature codes and layers, I was pointed towards FDM which I understood to be a standalone utility which would allow me to create my own feature code library. I've installed the programme but every time I open it it just throws an error message.
If anyone can point me in the right direction that would be great, doesn't seem possible to create layers in the feature code library editor in Access itself, so I need to get it working..
This is the mumbo jumbo the error dialogue box throws up. I've reinstalled several times, always the same. Surely I don't need TBC to run FDM? Installation Manager went on and opens fine.
Thanks!
Simon
(Inner Exception)
(Inner Exception)
(Inner Exception)
Exception Count: 1
Exception Source: CsdManagementWrapper
Exception Type: System.AccessViolationException
Exception Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Exception Target Site: csmSetGeodataPath
---- Stack Trace ----
Trimble.CsdManagementWrapper.CsdManagementPINVOKE.csmSetGeodataPath(String jarg1)
CsdManagementWrapper.DLL : N 00000
Trimble.Vce.Coordinates.CoordinateSystemDefinition.CSDefinition..cctor()
Trimble.Sdk.Coordinates.DLL : N 00264
(Outer Exception)
Exception Count: 1
Exception Source: Trimble.Sdk.Coordinates
Exception Type: System.TypeInitializationException
Exception Message: The type initializer for 'Trimble.Vce.Coordinates.CoordinateSystemDefinition.CSDefinition' threw an exception.
Exception Target Site: SetLicenseContext
Trimble.Vce.Coordinates.CoordinateSystemDefinition.CSDefinition.SetLicenseContext()
Trimble.Sdk.Coordinates.DLL : N 00000
Trimble.Vce.Coordinates.CoordinateSystemDefinition.CSDContainer..cctor()
Trimble.Sdk.Coordinates.DLL : N 00224
(Outer Exception)
Exception Count: 1
Exception Message: The type initializer for 'Trimble.Vce.Coordinates.CoordinateSystemDefinition.CSDContainer' threw an exception.
Exception Target Site: TypeInitialization
Trimble.Vce.Coordinates.CoordinateSystemDefinition.CSDContainer.TypeInitialization()
Trimble.Vce.Coordinates.SnapInInitializer..ctor()
Trimble.Sdk.Coordinates.DLL : N 00024
(Outer Exception)
Exception Count: 1
Exception Source: mscorlib
Exception Type: System.Reflection.TargetInvocationException
Exception Message: Exception has been thrown by the target of an invocation.
Exception Target Site: CreateInstance
System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
mscorlib.dll : N 00000
System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
mscorlib.dll : N 00142
System.Activator.CreateInstance(Type type, Boolean nonPublic)
mscorlib.dll : N 00107
System.Activator.CreateInstance(Type type)
mscorlib.dll : N 00013
Trimble.Vce.Core.AssemblyInitializerScanner.InitializeAssembly(Assembly assembly)
Trimble.Sdk.DLL : N 00261
Trimble.Vce.Core.RegistrationScanner.晫(Assembly A_0)
Trimble.Sdk.DLL : N 00009
Trimble.Vce.Core.RegistrationScanner.杦(Assembly A_0)
Trimble.Sdk.DLL : N 01434
Trimble.Vce.Core.RegistrationScanner.晫(String A_0)
Trimble.Sdk.DLL : N 00178
Trimble.Vce.Core.RegistrationScanner.ScanConfigAssemblies(Boolean noConfigIsError)
Trimble.Sdk.DLL : N 00975
Trimble.Vce.Core.ServerRuntime.桡()
Trimble.Sdk.DLL : N 00428
Trimble.Vce.Core.ServerRuntime.Start()
Trimble.Sdk.DLL : N 00072
Trimble.Vce.Core.Server.Initialize(Startup startup)
Trimble.Sdk.DLL : N 00157
Trimble.Vce.FeatureEditor.FEdit..ctor()
Trimble.Vce.FeatureEditor.DLL : N 00617
Trimble.Vce.FeatureEditor.FEdit.Initialize()
Trimble.Vce.FeatureEditor.DLL : N 00047
Trimble.Vce.FeatureEditorExe.Wrapper.Main(String[] args)
FeatureDefinitionManager.exe : N 00840
Date and Time: 31/05/2024 21:32:44
Machine Name: FURY
IP Address: fe80::f01a:55b8:1f16:603d%8
Current User: FURY\simon
Application Domain: FeatureDefinitionManager.exe
Thread Name: FeatureEditorExe UI
---- Assemblies in AppDomain ----
Assembly Full Name: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Assembly Full Name: FeatureDefinitionManager, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/FeatureDefinitionManager.exe
Assembly Full Name: System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Assembly Full Name: Trimble.Vce.FeatureEditor, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.FeatureEditor.DLL
Assembly Full Name: System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Assembly Full Name: System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Assembly Full Name: Trimble.Sdk.DiskIO, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.DiskIO.DLL
Assembly Full Name: netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/netstandard/v4.0_2.0.0.0__cc7b13ffcd2ddd51/netstandard.dll
Assembly Full Name: Microsoft.Extensions.Configuration.Abstractions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.Configuration.Abstractions.DLL
Assembly Full Name: Trimble.Vce.UI.UIManager, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.UI.UIManager.DLL
Assembly Full Name: Microsoft.Extensions.Configuration.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.Configuration.Json.DLL
Assembly Full Name: Microsoft.Extensions.Configuration.FileExtensions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.Configuration.FileExtensions.DLL
Assembly Full Name: Microsoft.Extensions.Configuration, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.Configuration.DLL
Assembly Full Name: Microsoft.Extensions.FileProviders.Abstractions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.FileProviders.Abstractions.DLL
Assembly Full Name: System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Assembly Full Name: Microsoft.Extensions.FileProviders.Physical, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.FileProviders.Physical.DLL
Assembly Full Name: Microsoft.Extensions.Primitives, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.Primitives.DLL
Assembly Full Name: System.Memory, Version=4.0.1.2, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/System.Memory.DLL
Assembly Full Name: System.Runtime.CompilerServices.Unsafe, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/System.Runtime.CompilerServices.Unsafe.DLL
Assembly Full Name: System.Text.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/System.Text.Json.DLL
Assembly Full Name: System.ValueTuple, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/System.ValueTuple.DLL
Assembly Full Name: System.Buffers, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/System.Buffers.DLL
Assembly Full Name: System.Numerics.Vectors, Version=4.1.4.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/System.Numerics.Vectors.DLL
Assembly Full Name: System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Assembly Full Name: System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Assembly Full Name: Trimble.Vce.UI.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.UI.Controls.DLL
Assembly Full Name: Trimble.Vce.UI.Wpf, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.UI.Wpf.DLL
Assembly Full Name: Trimble.Sdk.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Interfaces.DLL
Assembly Full Name: Autofac, Version=6.5.0.0, Culture=neutral, PublicKeyToken=17863af14b0044da
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Autofac.DLL
Assembly Full Name: Trimble.Sdk, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.DLL
Assembly Full Name: Trimble.Sdk.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Core.DLL
Assembly Full Name: Trimble.Vce.GE.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.GE.Core.DLL
Assembly Full Name: Trimble.Vce.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.Hoops.DLL
Assembly Full Name: Trimble.Vce.UI.BaseCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.UI.BaseCommands.DLL
Assembly Full Name: Trimble.Vce.InjectDependencies, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.InjectDependencies.DLL
Assembly Full Name: Trimble.Sdk.ConfigurationInterfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.ConfigurationInterfaces.DLL
Assembly Full Name: Microsoft.Extensions.Options, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.Options.DLL
Assembly Full Name: Microsoft.Extensions.DependencyInjection.Abstractions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.DependencyInjection.Abstractions.DLL
Assembly Full Name: Trimble.Sdk.Configuration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Configuration.DLL
Assembly Full Name: Microsoft.Extensions.Logging, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.Logging.DLL
Assembly Full Name: Trimble.Geodetic.AdaptorLibraryConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Geodetic.AdaptorLibraryConfiguration.DLL
Assembly Full Name: Trimble.Geodetic.OpticalLibraryConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Geodetic.OpticalLibraryConfiguration.DLL
Assembly Full Name: Trimble.Geodetic.LeapSecondsConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Geodetic.LeapSecondsConfiguration.DLL
Assembly Full Name: Trimble.GNSS.SatelliteSystemsConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.GNSS.SatelliteSystemsConfiguration.DLL
Assembly Full Name: Trimble.DefaultLegalDescriptionConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.DefaultLegalDescriptionConfiguration.DLL
Assembly Full Name: Trimble.LandXMLToGenio.ConverterConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.LandXMLToGenio.ConverterConfiguration.DLL
Assembly Full Name: Autofac.Extensions.DependencyInjection, Version=8.0.0.0, Culture=neutral, PublicKeyToken=17863af14b0044da
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Autofac.Extensions.DependencyInjection.DLL
Assembly Full Name: Microsoft.Extensions.Logging.Abstractions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.Logging.Abstractions.DLL
Assembly Full Name: Newtonsoft.Json, Version=13.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Newtonsoft.Json.DLL
Assembly Full Name: Trimble.Trdm.ServiceManagement, Version=2.20.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Trdm.ServiceManagement.DLL
Assembly Full Name: Microsoft.Bcl.AsyncInterfaces, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Bcl.AsyncInterfaces.DLL
Assembly Full Name: System.Threading.Tasks.Extensions, Version=4.2.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/System.Threading.Tasks.Extensions.DLL
Assembly Full Name: Trimble.Sdk.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.UI.DLL
Assembly Full Name: Trimble.Sdk.GraphicsModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.GraphicsModel.DLL
Assembly Full Name: Trimble.Sdk.Geometry, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Geometry.DLL
Assembly Full Name: Trimble.Vce.UI.Client, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.UI.Client.DLL
Assembly Full Name: Trimble.Vce.GE.Imaging.Gdal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.GE.Imaging.Gdal.DLL
Assembly Full Name: Trimble.Vce.GraphicsEngine2D, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.GraphicsEngine2D.DLL
Assembly Full Name: Trimble.Vce.ViewModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.ViewModel.DLL
Assembly Full Name: Trimble.Vce.TbcLicense, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Vce.TbcLicense.DLL
Assembly Full Name: PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
Assembly Full Name: WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
Assembly Full Name: PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
Assembly Full Name: System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Assembly Full Name: Anonymously Hosted DynamicMethods Assembly, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name: System.Diagnostics.DiagnosticSource, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/System.Diagnostics.DiagnosticSource.DLL
Assembly Full Name: System.ComponentModel.Composition, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.Composition/v4.0_4.0.0.0__b77a5c561934e089/System.ComponentModel.Composition.dll
Assembly Full Name: System.Runtime.InteropServices.RuntimeInformation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.InteropServices.RuntimeInformation/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.InteropServices.RuntimeInformation.dll
Assembly Full Name: Microsoft.Extensions.Configuration.Binder, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Extensions.Configuration.Binder.DLL
Assembly Full Name: Microsoft.Win32.Registry, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Microsoft.Win32.Registry.DLL
Assembly Full Name: Trimble.Sdk.Persistence, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Persistence.DLL
Assembly Full Name: Trimble.Sdk.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Utilities.DLL
Assembly Full Name: Trimble.Sdk.Units, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Units.DLL
Assembly Full Name: Trimble.Sdk.Primitives, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Primitives.DLL
Assembly Full Name: Trimble.Sdk.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Construction.DLL
Assembly Full Name: Trimble.Sdk.ForeignCad, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.ForeignCad.DLL
Assembly Full Name: Trimble.Sdk.RawData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.RawData.DLL
Assembly Full Name: Trimble.Sdk.Surface, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Surface.DLL
Assembly Full Name: Trimble.Sdk.Data, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Data.DLL
Assembly Full Name: Trimble.Sdk.FeatureDefinitions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.FeatureDefinitions.DLL
Assembly Full Name: Trimble.Sdk.Properties, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Properties.DLL
Assembly Full Name: Trimble.Sdk.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Features.DLL
Assembly Full Name: Trimble.Sdk.Coordinates, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.Sdk.Coordinates.DLL
Assembly Full Name: CsdManagementWrapper, Version=3.9.36.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/CsdManagementWrapper.DLL
Assembly Full Name: GeodeticXWrapper, Version=3.9.36.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/GeodeticXWrapper.DLL
Assembly Full Name: Trimble.CoreX.CSD, Version=2.91.13.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Feature Definition Manager/Trimble.CoreX.CSD.DLL
Simon Ham
